E-Class (W211) 2003-2009
Suspension clunks - where to start?
Old Jul 1, 2021 | 01:46 PM
eccentricVelo's Avatar
07 E550 4matic
Hi all,
First post here. I've had my 2007 E550 4matic for going on 3 years now and it's been pretty solid. I (and the shop) have replaced the front air suspension, radiator, new wheels, and some other deferred maintenance from the previous owner.
More recently, the car has developed a clunk, most predominantly from the front right. The clunk happens going over small bumps, big bumps, and washboards. The swaybar end links look ok and I'm thinking either the control arm bushing or upper ball joints. Is there a simple way to determine if those need to be replaced? Maybe it's something else that I haven't thought of? I'm all ears for any and all suggestions.
Thanks in advance!
Here's a pic of the car:
Old Jul 1, 2021 | 01:51 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Can’t check by looking… swaybar links are common, ball-joints, worn airmatic struts/mounts, etc…
Get a prybar and check for play. Rubber bushings, check for excessive cracks and/or disbonding.
Old Jul 1, 2021 | 02:27 PM
07 E550 4matic
Thanks for the advice! I'll check things out!
Old Jul 1, 2021 | 07:37 PM
F1Fan's Avatar
Upper ball joint is easy to replace. But also consider the stabilizer bar bushing. Earlier models had the bushing bonded to the stabilizer bar and eventually it would wear out and cause a clunk noise. Mercedes says to replace the whole bar to fix the problem. One way to check, disconnect the stabilizer bar links and go for a drive. Actually removing the links will probably be better to prevent them from hitting the bar accidentally. Or move the link out of the way. This will help guide you to figure out where the sound is coming from.
