Problem
That’s the rear brake caliper with fluid on it and no brake pad
Also proof read your shlt. You're asking people to take the time to answer your question, the least you can do is use punctuation.
I just was wondering what’s the liquid that’s coming out
to me it seems like brake fluid so I thought I would ask you guys
that’s gonna suck cuz it will be more money I got to pay
but you think the caliper is shot ?
So: if I'm seeing this properly, you're looking at:
A new caliper for one side
Rotors on both sides (replace them in pairs because your brakes are worth it)
Pads on both sides, for the same reason
Brake bleed all 4 wheels
Make sure your mechanic is knowledgeable on how to work with the SBC system on these cars. If the calipers are off the rotor and the car does a self check because he didn't deactivate the system, it gets ugly quickly.
Look at it this way: fixing your brakes properly is way cheaper than an Emergency Room bill. These electronically controlled brakes are truly amazing when they work properly.
