E-Class (W211) 2003-2009
airmatic pump
Old Jul 15, 2021 | 06:39 AM
larsk84's Avatar
mercedes e500 2006
airmatic pump
I bought my car 1 year ago and having the DTC 5503 recovery time during filling of central reservoir takes to long.
to start troubleshoot and look for leaks at struts, reservoir in back, valve pack, I checked my pump first. Something is not right , instead of an airfilter I have the Tube connected to a sensor, seems like a pressure sensor. ( when I unscrewed the clamp the sensor has a pointy end).
also the car makes loud hising/ pressure releif sounds, noticable when coming to traffic light stops etc.
Pressure sensor ?
Old Jul 16, 2021 | 03:53 PM
rodneypierce's Avatar
2009 e550 4Matic
I'm willing to bet that pointy ended sensor that someone has jammed in there is your outside temperature sensor. Should go on the front bumper. Just judging by what it sounds like from your description.
Old Jul 16, 2021 | 03:55 PM
2009 e550 4Matic
Oh, and the hissing/pressure relief sounds are perfectly normal. The car is adjusting ride height as you approach a stop.
Old Jul 16, 2021 | 04:32 PM
larsk84's Avatar
mercedes e500 2006
But If a connect a air filter instead of temp sensor , where should I continue with a hose after filter?
Old Jul 16, 2021 | 05:01 PM
2009 e550 4Matic
You could litery run it upwards anywhere into the engine compartment, just make sure the end isn't able to get water/sand/etc down it.
