E-Class (W211) 2003-2009
Shift module reassembly question
Old Sep 6, 2021 | 05:44 PM
Smaug6's Avatar
05 E320 CDI
Any help appreciated guys! I have a 2005 e320 CDI with 218000 miles. Got it for $1000 with a bad ECU. Got about $6000 in it! I love this car! Anyway I got put into limp model and scanned it with my MB II scanner and the transmission showed code 240 shift position unknown! I found the thread about the cracked solder joints so I took it apart to check! I couldn’t see any cracks but I hit it with the solder tool on a couple that looked funny. So during reassembly I cracked the shaft follower and repaired that with two part epoxy. Went to put it back together and I can’t recall how the three components in the middle of the pic go back together. Does anyone know of a diagram or picture of this assembly? I’m almost done with this and this is the only holdup! If it doesn’t work I’m gonna explore a refurbished unit. Do they have to be programmed? Thanks for any assistance btw!!!!
Three pieces on the right middle.
Old Sep 8, 2021 | 10:06 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
You did not need to pull it apart to get to the shift lever detection sensor. If you obtain a replacement shift module, however, you do not need to program it to the car. Based upon a previous post by another user, a brand new one must be "activated" but can then be interchanged among different cars. For now, you're going to have to figure it out like a puzzle.
https://mbworld.org/forums/w211-amg/...ml#post8406592
Old Sep 8, 2021 | 10:34 AM
Smaug6's Avatar
05 E320 CDI
Thank you
