2007 E350 - Fuel Tank Warranty still covered?
Is this car still covered by MB's fuel tank warranty? Do I call MB of North America to find out?
Many thanks in advance.
Any ideas on a potential fix? This is a very clean black on black car with no body or interior damage. Runs great when the pump works. Looking for options. Thanks for any ideas. Mark
VDO -> https://www.fcpeuro.com/products/mer...vdo-2114704194
Genuine Mercedes (currently on sale) -> https://www.fcpeuro.com/products/mer...ump-2114704194
Even with the most expensive indy you can find, it is well worth it. The pumps are wear items, and they already gave you 150K miles.
Talk to the dealer and see if you are lucky; otherwise, you are still golden anyways that it is not the intake manifold damaged, or some other pricey stuff.
. My apologies then.. I should have re-read your original post before concluding.If I were you I would explore the possibility of "MB USA courtesy" either via the friendliest dealership you have interacted with during those years, or directly write a "very smooth" letter to MB USA and see how it goes. MB USA has not too much loose (deep pockets), and some of those tanks on inventory can be written off anyway. The problem I see is the labor cost, which is hard-fresh money nobody would want to part with. Perhaps you may get an offer with you to pay for labor, and they give you the major parts or a heavily discounted price. The question is who can deal with MB USA better, you or a friendly SA championing for you.
Hope you have a spare car in the meantime; otherwise, that puts even more pressure on getting any solution w/o proper time to think about it.
Definitely, someone at MB engineering group was smoking something.
Now I can see how they will fix it overseas. Fill it up with water completely, and open it apart, replace the pump and weld it again. Or, just use a non-PZEV tank and call it a day.
I have spoken to two dealerships, same story. They want me to tow the vehicle in, let them inspect it and make a decision. Basically they want the car so they get the job knowing there is no warranty in advance. I will pull it apart, I am ASE certified from a past life so it is just a pump but a very complicated system.
Looking at options, it is a metal tank, I know a very good certified welder. I have thought about cutting it open, install a new pump and have him weld it closed again. I would have to go with his expertise, some metals are thick enough and OK to weld like that and others are not. He has built many tanks for custom vehicles.
You are better hands than I thought, yourself and a certified welder
Full PZEV Tank removed, lines still attached. NOTE: All lines on the PZEV tank are metal and use threaded connections, no plastic or rubber outside the tank.
Fuel filter cover Driver side of tank
Fuel Filter cover with electrical removed.
PZEV Tank with new access hole cut to get to fuel pump module. The metal plate cut out is sitting on the left of the new access hole. It could be welded back in.
PZEV Fuel Pump module. Comes out with two quick release clips. It was made to be replaceable but they did not give you access to do this job.
This is the pump that is inside the Module. IF we can find a replacement Pump the Module could be reinstalled. The tank opening would need to be welded or fixed with a sealed door for access.
This is the top of the fuel pump, note the hose connector type and it is a standard two wire power connector, one 12V and one ground.
Second picture of the fuel pump connections in side the module.
world forum trying to find answers to my PZEV fuel pump failure and most of the notes on what has been done are reported on that forum if you would like to read up on this.
I will report that I have now removed the Fuel Tank from the car, not an easy job. The exhaust, Driveline and the complete rear suspension has to be removed to take this tank out. The only reason for all this work is that Mercedes decided not to add a window in the top of this tank to allow a fuel pump installation.
The dumbest feature delete I have ever seen on a car build. They put in a trap door for the filter replacement in this same tank so it is not for emissions I think it is for cost cutting. So a 1 hour job is turned into 12-15 hours. Mercedes wants you to install a complete new gas tank with the new fuel pump installed.
I removed my tank, cleaned it fully inside to remove the gasoline. Then I cut an opening in the passenger side of the tank to gain access and look for the fuel pump. The pump is right where you would think, just under the place where the access hole should be located on the passenger side. Once open the pump is held in place by two very nice quick disconnect locks, one fuel line and one electrical connection. So with the tank open the pump comes out in about 5 minutes. The problem is no body sells this easy to install fuel pump. I am looking for a pump that fits and works properly in this application and then I am looking for options to seal the tank properly once a pump is installed. These metal PZEV tanks are very high quality steel. The fittings and connections are all steel. More like a race tank connection than a passenger car design. If it just had a removable access door on the passenger side they would be perfect for the life of the car. I will try an update once it is back in the car. I ordered a pump to install inside the fuel pump module. It will arrive in a week or so. That should fix the pump module but I still need to decide on how to close the fuel tank. Welding is the easy way but would not help at all if this ever needs to be opened again.
, and write-up For closing the tank, I wonder if you could use a similar mechanism as used in the non-PZEV tank or equivalent. The tricky part is the plastic flange attached to the tank since the cover can be the top of the non-PZEV pump unit w/o the internals, i.e, just the seal and the cover. Then, you can buy new seals, cover, large nut, i.e. standard available parts.
Regards
I found a better pump solution, The Mercedes pump for a S500 I think was a perfect replacement, I still had to take apart the S500 module and put the new pump inside the old E350 PZEV module but it was an exact replacement pump and is still working perfectly today. No leaks or issues. The good part was when the Carter pump failed it only took about 2 hours to install the new Mercedes pump because I had access with the new access plate. Beat the heck out of removing the entire rear suspension, and driveline, and exhaust system to pull the entire tank from the car. Final wrap, the repair worked. Edit: a full write up with far more pictures and the removable access door is available on the Benzworld forum you can look it up.
