E-Class (W211) 2003-2009
Code 5503, no leaks rebuilt compressor
Old Sep 12, 2021 | 10:27 AM
larsk84's Avatar
mercedes e500 2006
Hi
Im out of ideas, I checked all shocks with spraying soap water I rebuilt my air compressor with kit from ebay(new gasket and piston ring) and a removed my airtank in trunk and drowned it in pool of water - no leaks anywhere.
all I havnt’ checked is the relay for pump.
when I use my i980 icarsoft to monitor airmatic pressur sensor, as soon as I go into suspension > actual values, this command stop the function of the compressor. As soon as I leave the suspension menu the pumps starts again. So therefor I can get a accurate reading (takes about 5 sec from it stops to my scanner to load 2 menus. But when I do this I get 7 bar from B7 airmatic pressure sensor. But I suspect this value is higher because of my scanner as i described.
car sits fine I dont see any corners ever going down
