Noob W211 question
I'm looking at purchasing a W211 E-class Merc here in Australia. I have the option of purchasing an older model (2004 E320) with SBC or a newer 2007 model E280.
I feel that the newer model would be a better buy, even if it costs more initially. I really don't want to be replacing SBC parts and have an undriveable car in the downtime.
Thoughts? This is what I'm interested in - https://www.carsguide.com.au/cars-for-sale/D_12207821/
- M272 Engine Serial No. 2729..30 468993
- M273 Engine Serial No. 2739..30 088611
Now to the intake manifold, the listing indicates @128K km ~ 80K miles. Assuming good maintenance (and luck), the intake manifold may still be OK; therefore, it would be a good idea to scan for codes in case the manifold level is already broken (it does not trigger CEL engine all the time), check for oil in the hose from the PCV to the throttle body, and if you buy it, I would replace the PCV valve immediately to prevent/protect the intake manifold. The question is not if it will fail, but when.
Sis has the W211 with 165K miles (intake is damaged already), but the transmission seems solid, no issues, but it has been maintained by dealer+Indy, so the oil change nuisances were paid for.
Definitely, I would not buy a used vehicle with SBC. It was a technology failure (not criticizing the tech behind it, but no longer supported); otherwise, every MB would have it today.
With the scanner, I have a generic Foxwell brand scanner. It can clear codes as well. Will this pickup any codes or do I need a better one? (I paid around US$50 for it from AliExpress.)
Thanks for the VIN checker link. Much obliged.
Intake manifold runners get stuck when the oil separator/breather cover goes bad and allows oil into the intake which gums up the flaps. When the flaps don't move or are hard to move, you get pending error codes or a CEL light at some point. On the other hand SBC can fail at any point as it's a mechanical pump. MB keeps count of how many times you use the brakes and issues a warning when it thinks the pump might fail, but again, anything mechanical can fail at any time. SBC is like driving with brakes that might fail at any point if you're near the end point of the pump life. A bad intake just means the engine runs a little rough. Intake is about $650 in the US, Pierburg is the OEM maker. I had it replaced for about 1k as you also need gaskets and o-rings for the fuel injectors. Many youtube videos on how to replace the intake. The balance shaft problems affected all 2006 models and some 2007 models that had the M272 engine, as mentioned earlier, use a vin decoder like the one below to check the engine serial number to make sure it's out of range.
https://www.lastvin.com/
https://www.fcpeuro.com/products/mer...kit-oem-515810
The ECU doesn't really go that often but it's possible. I think you might be able to get that rebuilt, at least in the US. Same with the conductor plate for the transmission, that's $200-$400 for the conductor plate to be rebuilt. Probably 1k for a new one as it also needs to be programmed by the dealer afterwards. If you rebuild it, it doesn't need to be programmed but you do have to wait while you send it out and wait to get it back. Not sure if there's a company that does that in your country. The 5 speed in the 4matic is more reliable than the 7 speed in the RWD model, but then you could have issues with some of the 4matic hardware so it's a toss up. But you could get conductor plate issues across all years.
As for scanners, there are many out there. You want one that can read MB specific codes. There might be a pending intake manifold error code that your generic Foxwell scanner will not pick up. Foxwell also makes scanners that can do MB specific codes. iCarsoft, Autel, Launch, etc all make scanners that can do MB specific codes. One of the cheapest out there from Launch is the Thinkcar Pro on Aliexpress.
https://www.aliexpress.com/item/1005002100144322.html
My Foxwell scanner is a NT301 model. Would that still pickup problems or would a MB specific scanner be better?
Also, I remember reading in another thread that even the balance shaft issue appears in only 2% of cases - so the older models are still worth exploring.
I am now the proud owner of a 2007 E280 Elegance sedan, black in colour. I've never owned a black coloured car before!
VIN WDB2110542B198601
Engine no 27294330687005
When I scroll through the display on the speedo, it says Service E due in roughly 14000km. What does a Service E involve? Can I get it done now or wait until 1 year or 14000km passes?
I travel roughly 10000-15000km per year. I have yet to check when the last service was done.
Service due that far down indicates it might have been recently serviced; however, I would take to a trusted mechanic and get it checked. Call me paranoid but anyone can reset the indicator w/o truly performing the service. Take that chance?
I will be taking it to a mechanic soon. (Within the week.) Thanks once again to all that replied.
My intake crank failed, had it set wide open and see no reason to fix it, as it runs fine, passed Calif. smog every 2 years. 27 mpg on the highway, maybe a little under normal around town?
