E-Class (W211) 2003-2009
Analog Dual Zone Climate Control
Old Apr 21, 2022 | 01:45 AM
S211estate's Avatar
2006 E350 Wagon
Hi, I have an issue with the air blowing (slightly) warmer and weaker on the driver side vents.
I suspected it was just a bad heater valve, so I just installed a brand new heater valve today. But it didn’t fix it.
What could be the issue on this case?
Anyone has any idea?
Old Apr 21, 2022 | 11:58 AM
konigstiger's Avatar
'71 Pinto
Check refrigerant level if fine, have some pull fault codes using MB diagnostics.
Old Apr 21, 2022 | 03:14 PM
S211estate's Avatar
2006 E350 Wagon
Thanks, konigstinger!
Yes I’m gonna check on Freon first. I rarely see people talk about the control unit failure, but curious, could it possibly be the bad climate control unit?
Old Apr 21, 2022 | 03:22 PM
'71 Pinto
Anything is possible but if refrigerant is fine I would opt for codes before replacing parts.
Old May 6, 2024 | 07:58 AM
Profa's Avatar
mercedes benz w211
Hello, did you solve this problem? i have the same problem.
