E-Class (W211) 2003-2009
Need help to remove rear window of my 2002 w211
Old Jun 8, 2022 | 04:53 AM
Tayfun's Avatar
W211 2002 e220
Hey, i need to remove my rear mirror to try a solution i found online for loose mirror, but when i tried to remove the mirror's metal bar thing that the mirror attaches to, i couldnt pull it out by just pushing it down... cant do it with my mirror because it doesnt really fit in it well... someone have an idea how to remove that metal part ? Because i couldnt find any screws etc as well
Old Jun 8, 2022 | 05:55 AM
Heguli's Avatar
2006 E280
There is a metal spring that's holding the mirror. It's quite tricky to remove, I had to use screwdriver to assist with. I did notice that it's quite straightforward to remove if you know how to do it. Of course, now I can't remember the exact procedure.
Old Jun 8, 2022 | 06:36 AM
Tayfun's Avatar
W211 2002 e220
in the image where the cable goes through at the top part, i saw a spring there actually is that the one ? I tried to play with it with a screwdriver but didnt work, maybe didnt do it the right way if that's the one
Old Jun 8, 2022 | 11:30 AM
konigstiger's Avatar
'71 Pinto
File Type: pdf
