E-Class (W211) 2003-2009
Differential aspect ratio problem
Old Nov 2, 2022 | 09:20 AM
BENZSRB's Avatar
MB W124 230E 1986.
Hello Guys
Did anyone successfully solve this problem? I install rear differential on my 2007 S211 220CDI 125kw from 2007 W211 220CDI 125kw. Differential aspect ratio on S211 is 2,82 and 2,65 on W211. Now i facing the problem with automatic gearbox which goes to the safe mode. I did not do this by mistake, there is a purpose. I do lot of milleage without heavy load and and this aspect ratio diference makes a change in fuel compsuntion.
Any experience can be useful, thank you.
Old Nov 2, 2022 | 10:19 AM
E55Greasemonkey's Avatar
This place is a joke.
You will have to find a tuner to change the gear ratio in your transmission control unit, if you have the 722.9 7 speed this may not be an easy task. The 5 speed can be tuned for the different gear ratio as well, you would have to send your TCU to a tuner.
Old Nov 7, 2022 | 07:28 AM
BENZSRB's Avatar
MB W124 230E 1986.
So, you think that this is possible?
Gearbox is 722.6, 5 gears. Thank you.
