E-Class (W211) 2003-2009
Rear Brake pads and rotors replacement
Old Nov 22, 2022 | 04:11 PM
terracotta's Avatar
2006 E320 CDI
Dear members,
Could someone point me to the specific procedure for the rear brake pads and rotors replacement on the E320 CDI 2006? It would be great if there was a step by step video of the procedure.
1) Is it advised to always replace rotors (even if they are good) or should one then only replace the brake pads?
2) Are there any recommendations on superior upgrades for this vehicle instead of OEM parts? Which parts would you recommend?
regards
Old Nov 23, 2022 | 07:30 AM
hangit06's Avatar
2006 E320 CDI
https://www.pelicanparts.com/techart...eplacement.htm
Old Nov 23, 2022 | 11:17 AM
terracotta's Avatar
2006 E320 CDI
thank you for the link. I have seen it. However, my question was what is your experience with mounting aftermarket EBC red stuff pads and pairing them with an appropriate rotor or some such combination. What would you recommend.
My front brakes are good and they are stock. Is is a good idea to go aftermarket performance brakes for the rear and leave the fronts stock? Will that cause imbalanced braking or vibration?
