E-Class (W211) 2003-2009
Creaking when turning slowly
Old Jan 18, 2023 | 02:27 AM
Axe Murder's Avatar
E55
Question Creaking when turning slowly
I am guessing ball joints?
No sound when driving over bumps, or at higher speed. Only when turning sharply at parkings.
Tie rods were swapped at 84k miles, the car is now at 109k miles.
Also feel like the self-straightening after turns diminished notably.
I guess my question is rather "How do I know if it is ball joints, tie rods or bushings?"
Old Jan 18, 2023 | 04:43 AM
Heguli's Avatar
2006 E280
edit/ Didn't know what I was talking about.
Old Jan 18, 2023 | 12:04 PM
tjts1's Avatar
C320
It's likely the steering rack mounting plate which is known to generate noise on early 211s. There's an updated part number.
Originally Posted by Heguli
I'd say it's the strut mount/bearing, up in the wheel well.
​​​​​​​That's an interesting theory considering that 211 doesn't have struts.
Old Jan 18, 2023 | 12:24 PM
konigstiger's Avatar
'71 Pinto
See attached bulletin.
File Type: pdf
Old Jan 18, 2023 | 01:05 PM
Heguli's Avatar
2006 E280
Originally Posted by tjts1
IThat's an interesting theory considering that 211 doesn't have struts.
My bad. Shows how much I've lurked in the wheel well of my car
Old Jan 18, 2023 | 02:58 PM
Axe Murder's Avatar
E55
Thanks for the bulletin! Mine does however have a later VIN. It's a facelifted 2008 wagon, so S211 strictly speaking.
It has double wishbone? I would never have guessed it, despite having stared at the suspension a dozen times.
My brain just kind of saw the bulb wells and went "Yeah, MacPherson". But now I just had to look it up.
Old Jan 18, 2023 | 03:17 PM
Heguli's Avatar
2006 E280
When you find the issue, please inform us. I have the same issue, only happens when turning left, almost full lock. I'll need to fix it, after more important issues are solved.
Old Jan 18, 2023 | 07:18 PM
cetialpha5's Avatar
Noises are hard to diagnose online, you really need to take it to a mechanic to have him check it. There's lots of things that cause noise down there and sometimes it's not what you think it might be. There's also sway bar links, motor mounts, the sway bar, bushings, wheel bearing, cv joint, brake pad/backing plate, etc.
Old Jan 24, 2023 | 02:29 PM
Axe Murder's Avatar
E55
I think I found the issue, though I haven't fixed it yet.
Read here about possible suspension problems: https://vroomo.co.uk/mercedes-w211-suspension-issues/
Apparently, ball joints are lubricated inside those rubber boots, and when the rubber cracks the oil seeps out and the ball grinds in the socket.
Upper right side:
Everything else was nice and tight, albeit dirty.
I'll swap on both sides pronto. It's a $30 item weighing less than a pound, held by three nuts on the top.
Old Jan 24, 2023 | 03:25 PM
Heguli's Avatar
2006 E280
I had my car on the jack stands last sunday when I made a new rear brake lines. Completely forgot to check the creeking source, when I had all the room to do it while bleeding the brakes.
