Oil leaking into throttle body
picture taken before cleaning area
Check condition of the harness connector for oxidation and the ECU GND posts on your chassis to minimize transient voltage spikes.
These engines injest a lot of their own oil even through a new PCV. The oil type and grade are very important to help minimize the issue a bit.
What modifications are on this vehicle?
Check meticulously around the engine bay for loose or broken tubes and pipes that could allow air into the induction system.
no mods, with a basic OBD2 scanner it throws me a P2135 code, an I will check for broken tubes
brought car to a Benz dealer and had a service check on it, said potentiometer was the issue in the TB so I bought a new one (again) and am going to install. Hopefully this time no issues will arise after installation since it was bought from MBparts website and not eEuroparts or FCPEuro.
You will want to get a wiring diagram so you know where to test this. The WIS has it but I find those wiring diagram hard to use. Consider a limited AllData subscription (very low cost for a few days) and they have really good wiring diagrams.
