E-Class (W211) 2003-2009
W211 pedal position sensor issue?
Old May 1, 2023 | 05:10 PM
2008kenw211's Avatar
w211 e350 4matic
Hello,
Sometimes while in Park or Neutral my car will rev up to 2,000rpm and drop back down below 1,000.
It does it when both when I press on the pedal and even when i don’t.
I don’t think it’s an issue with the throttle body because I installed a new one recently, im thinking about going to a Mercedes dealer and getting it diagnosed there unless anyone on here knows what could be the issue.
Im guessing it could be the pedal position sensor itself.
thank you.
Old May 1, 2023 | 06:44 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
wildly unstable idle...
Originally Posted by 2008kenw211
Hello,
thank you.
The engine computer needs to be trained to use your new throttle body. This is done using MB Xentry....
I think replacing TB contributes this additional issue. Original problem maybe: air bypass, MAF, ...
Recommend scanning the car for live faults before TB pushes ECU into limp-mode.
Throttle command has safety considerations.
Old May 1, 2023 | 07:36 PM
w211 e350 4matic
Thank you,
where do you recommend purchasing this MB Xentry?
Old May 2, 2023 | 05:40 PM
Thank you,
The answer would be @BenzNinja with acclaimed remote service... so I hear
Old May 4, 2023 | 06:57 PM
taylor210's Avatar
02 E320 Blk, 09 E350 Blk
Try this!
Hello,
thank you.
Recently removed TB out from w210 and w211 to clean out all the gunks around the TB plate turning it manually by hand.( goes only one way). All cleaned nice and installed back, turned the engine the rpm jumped up n down too much.
Shut off the engine. Turn the key to #2 position(do not start)
Open the hood, put your ear close to TB, wait about 30 sec then you’ll hear click click sound from the TB plate. Ecu resets the TB, now start the car and rpm will be smooth as silk
Just try it, you’ll feel better
Old May 27, 2023 | 03:57 PM
w211 e350 4matic
Does nothing…
I’ve tried this multiple times at it has done nothing to fix my issue.
Old Jun 5, 2023 | 03:25 PM
e350forme's Avatar
fleet
how about the press pedal down for 10 seconds and let the throttle body open and close it self/reset
Old Jun 5, 2023 | 09:45 PM
w211 e350 4matic
when I do this with the key in the second position it causes the ESP inoperative message to appear on the gage cluster screen
Old Jun 6, 2023 | 10:41 AM
e350forme's Avatar
fleet
esp messages (that I have had) are caused by a bad reluctor ring on an axle and then ABS /ESP turns off. does your power stearing get stiff?
Old Jun 6, 2023 | 10:42 AM
e350forme's Avatar
fleet
have you had the car smoked to check for vacuum leaks also, it could explain the idle issue
these are all basic things that any mechanic can help you with like pulling axle or attaching a smoke machine with a vacuum
Old Jun 6, 2023 | 11:48 AM
w211 e350 4matic
only time the steering was still was during the winter but only when the car was cold
