E-Class (W211) 2003-2009
OM648 oil change info
Old Oct 4, 2023 | 12:34 AM
ot1's Avatar
ot1
2006 E320 CDI
Arrow OM648 oil change info
After adding 8 quarts of Mobil 1 European full synthetic (0w40) and filter change.
With engine OFF and center dash readout displayed 7 quarts
With engine RUNNING @ IDLE, oil level slowly started dropping, after about 5 minutes, displayed 5.5 — 5.6 quarts.
With engine OFF and now at rest for 20 minutes. Using Baum 120-0721 dipstick bottomed out, oil level was @ 140 cm, top of dip tube was @ 740 cm.
Although the vehicle looks level, using a iPhone 14 level app, at the rear of the filter air box, reads 0 degrees,
but the engine is canted higher at the front and the iPhone reads 3 degrees.
Is there any WIS information that differs ?
3 degrees on engine
0 degrees on air filter box
