E-Class (W211) 2003-2009
My 07 e350 cranks but won’t start!
Old May 5, 2024 | 09:47 PM
Mohammed_ksa's Avatar
MB 2007 E350
Exclamation My 07 e350 cranks but won’t start!
While driving on the highway, my car suddenly shut off after I pressed the gas pedal forcefully, and the gear got stuck on 3rd before shutting down, but overall the gear is fine and can be parked. Initially, I suspected running out of gas due to the faulty gas odometer. After refueling, the car still wouldn't start. I jumped start it too, and nothing happened. Returning home, I began diagnosing the issue. I utilized an OBD scanner, specifically a FOXWELL, which detected several trouble codes, including P02158, P0336, P0560, P0627, P0366, P0391, and U0155.
Up to this point, I've replaced the intake manifold actuator, camshaft sensors, crankshaft sensor, battery, and MAF sensor.
I've also inspected all fuses and relays, confirming their good condition. Additionally, I checked the fuel pump pressure during cranking, which registered around 55 psi. I took the alternator to AutoZone for testing, and it's functioning properly.
Is there anything else I should consider checking? The car has been parked for the past 2 months, with the issue remaining unresolved.
Old May 10, 2024 | 07:51 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
How did you go with this? Sorted or still problematic
