E-Class (W211) 2003-2009
2004 E500 4MATIC REAR AXLE'S
Old Jul 17, 2024 | 07:23 AM
dreib's Avatar
E300
I have a terrible popping noise when turning, especially slow sharp turns forward or reverse. Checked diff and did a oil change , looked good and no sparkles so Im guessing its the rear cv axles.
I cannot find rear axles for the 4 matic...anyone have a part number ?
Or maybe an alternative idea of what is popping in the rear. ....maybe a wheel bearing?
I look forward to a reply sometime in the next millenia ?
Old Jul 17, 2024 | 08:29 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Popping is usually something in the suspension. Usual culprits: arb bushings or arb links
Old Jul 17, 2024 | 08:51 AM
dreib's Avatar
E300
Hmmmm, interesting. Why would that make a popping sound.
Old Sep 6, 2024 | 04:48 AM
Pig's Avatar
Pig
E500
Do you still need an axle?
Old Sep 6, 2024 | 06:37 AM
dreib's Avatar
E300
So after extensive research we believe this could be an issue with the transfer case fluid EOL. We are going to flush out the transfer case add new fluid and see if that takes care of it next week. Been super busy with other projects .
I will try and remember to report back!
Old Sep 6, 2024 | 07:37 AM
Pig's Avatar
Pig
E500
Ah, okay.
(I needed an axle replacement recently because the "ABS ring" in it was shot.)
Old Sep 20, 2024 | 03:39 AM
Sandygear's Avatar
2004 e500
You'll want to replace the fluid a second time after about 30 miles. Had to do it on mine and worked great.
Old Sep 20, 2024 | 06:29 AM
dreib's Avatar
E300
Weird...Im doing the work (finally) this weekend. There is probably zero chance I do the service then redo the service again in 30 miles since im on jackstands and its a pain in the *** to do the work!
I am going to swap fluids ,start the car and put it in gear to spin things around then replace the fluid again. Hopefully that will help and I hope it takes care of the issue.
Thanks!
Old Sep 21, 2024 | 12:56 PM
Sandygear's Avatar
2004 e500
Old Sep 21, 2024 | 06:15 PM
dreib's Avatar
E300
yea saw this but you have to pay to watch the actual procedure so i just did it like I was planning and if it needs to be done again no big deal now that i have actually done it!
Thanks !!!
Old Sep 22, 2024 | 07:14 PM
dreib's Avatar
E300
UPDATE !! JOB COMPLETE
Thanks !!!
So did the transfer case fluid change(2004 E500 4matic) and the horrible popping/grinding sound is gone. Its hard to believe it was as simple as that but it was! I measured what came out and replaced the fluid twice. I did not drive in between just started the car and let it the wheels spin a little in drive and reverse.
Pretty easy job but would be easier with a lift. Getting too old for jackstand projects but didn't feel like paying $475 to have a garage do it.
Hit me up if anyone has questions.
Old Sep 24, 2024 | 06:44 AM
dreib's Avatar
E300
UH OH...UPDATE 2
SandyGear was right!!
Drove the car last night and the issue returned although it went away after driving a little, never the less I am going to take the car out for a long drive this weekend then do the procedure one more time then go on another long drive.. hopefully that will do the trick. Hopefully this thread will help someone down the road? I will report back.
Old Oct 2, 2024 | 07:05 AM
dreib's Avatar
E300
Did another fluid exchange. The transfer case still hangs up a little when cold but it all goes away within 5 minutes of driving and Ive only driven the car maybe 5 miles since this second service. Im guessing it will keep improving as we drive it longer. Time to move on to other issues I have with the car.
Thanks!
