E-Class (W211) 2003-2009
Pyro fuse
Old Aug 10, 2024 | 07:13 PM
usman1234's Avatar
N/a
Pyro fuse
W211 - 3.0 Avantgarde 2007 - Right hand drive.
Hi everyone,
We've got an issue. Car won't start. No lights on dash. Nothing. Battery is new. Alternator is fine. Thought initially it would be the pyro, but not sure if this model has a pyro. No idea what else it could be.
Any ideas?
If it does have a pyro, where would it be located.
Old Aug 11, 2024 | 04:11 AM
Heguli's Avatar
2006 E280
No pyro on these as far as I know.
Not starting, I assume you can turn the key to the start position?
Old Aug 11, 2024 | 05:39 AM
usman1234's Avatar
N/a
Oh ok, thanks for letting me know. Saved me from ripping it apart.
Correct. It the key turns fully to the start position.
Old Aug 11, 2024 | 11:04 AM
usman1234's Avatar
N/a
Apologies.
The key doesn't turn to the start position. We had it in neutral via shift lock override. The key turns when in this position. Can pop into other gears. Once back in park, the key doesn't turn.
