A/C blowing hot air unsure why
just gonna tag ppl who have helped in the past
@juanmor40 @Plutoe
1 - car off for a while, so refrigerant pressure reaches lowest value
2 - scan the vehicle, and take those snapshot
3 - car ON, AC at MaxCool or LO setting, engine @1500 rpm
4 - scan again, snapshots
The previous snapshot show low refrigerant pressure.
For the low pressure, you need a set of pressure gauges. In the US you can borrow/rent them from AutoZone/Advance Autoparts
Also, the iCarsoft report a super negative temperature, -146 F, for the refrigerant because the facelift W211 does not have the sensor anymore.
The chart above is for refrigerant R134a, you can read refrigerant pressure for the ambient temperature, 102.2 F in your snapshot. -> 128 psi. Assuming the cars Temperature sensor may 1 or 2 F error, it seems the computer reported pressure of 137 psi is about static pressure in the system when off, or a barely actuated compressor.
Recheck, to confirm those pressures are correct.
Now, the snapshot shows compressor being actuate at 70% , but pressure is not increased. Why?
Is the electronic control valve working correctly? You can do two test at the compressor:
- disconnect wiring to the compressor
- measure resistance between contacts on the valve, note it
- measure voltage at connector, note it. Do NOT ground this contacts since it is a control signal, not a power signal.
If you conclude it is the compressor, the system must be cleaned, flushed well. New drier, condenser, compressor + ??. You need to know why it failed, or the new one WILL fail again quickly
checked the pressures with gauges static pressure was reading 75psi on low side, and 85psi on high pressure. With rpm’s @1500 max ac the readings were 80psi on low side, and high side was still 85 psi. The ambient temps are 80 degrees Fahrenheit. Also scanner was plugged in reading 70% again on the compressor also this there was a very loud screeching noise.
Undervoltage sounds you have a weak battery, but the exact message will help.
These vehicles require batteries to be charged at all times and healthy. Otherwise, all kind of error messages and malfunctions start to happen.
