E-Class (W211) 2003-2009
Anyone have problems with your Airmatic?
Old Mar 2, 2005 | 12:41 PM
jack500's Avatar
2005 E500 Brilliant Silver
I am really getting tired of taking my car back to the dealer. The Airmatic is always off. It sits high in the rear left. Any ideas of what could be causing this?
Jack
Old Mar 2, 2005 | 12:56 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Jack
Mine is low rear left... I have sent it in, they said it was fine (although it came back perfect) and now it is back to the way it was..
It seems my steering wheel pulls right, which would make sense for a low back driver side.. So when it gets warm I am going to take it back in.
Old Mar 2, 2005 | 02:02 PM
jack500's Avatar
Mine also pulls to the right. I have taken it to the dealer four times. I wonder if this is common? Anyone else with the same problem?
Old Mar 2, 2005 | 02:15 PM
marcos's Avatar
ML 320 CDI
Yep, same problem. I've given up trying to get it put right now and as I'm looking at new cars at the moment I've lost interest in getting it done.
Old Mar 2, 2005 | 11:56 PM
jdm2ths's Avatar
w211
my E500 sits higher in the rear right..... i sent it in they change my shock to a new one and it still sits the same... the tech's that i have talked to said its normal for airmatic....
Old Mar 3, 2005 | 10:53 AM
sleonard's Avatar
Problems as well!
'04 E500 w/1200 miles on it. Sitting low in the left rear. Measured fender height from center of the tie. Fluctuates between same level and l" lower.
MB service "played with it" (raising and lowering) and got it to be even. Took back a second time. Sames drill all over again. They suggest replacing the strut if it continues.
Major problem is as follows. Airmatic has three leveling sensors: 2 in front (1 per wheel), 1 in rear (in center of the axle). So, there is no good adjustment in the rear.
Please post updates if more is learned.
Thx.
Old Mar 3, 2005 | 03:20 PM
jack500's Avatar
Thx.
I have also heard that the rear sensor is the one that creates the problem. I have only had the car a few months and this is the only problem I have experinced. Any other common problems I should look for?
