Does anyone know of any cool hacks for the new E class?
Old 12-03-2013, 01:45 PM
  #251
FastE's Avatar
2020 MB-AMG GLC43
Originally Posted by dmighty
Yes, every time unfortunately. I won't connect any other way. The phone reconnects, no issues but no audio. So I deauthorize and then do a external authorization.
I really suggest the adapter I have - listed above. Anyone in this forum driving an E W212 can afford the cost. It works seamlessly even with an iPhone 5 - my phone never comes out of my pocket.
Old 12-03-2013, 05:35 PM
  #252
Arrie's Avatar
You need the software update.
Old 12-04-2013, 05:01 PM
  #253
timurik's Avatar
e350
sirius radio
You can listen to Sirius radio even if your subscription has expired. But the catch is you can listen to only one channel you choose. If you change switch the channel you will get into the preview mode like you have it right now. To activate your one channel, you need to go to the engineering mode.
Old 12-04-2013, 05:30 PM
  #254
FastE's Avatar
2020 MB-AMG GLC43
I will have to try that! I suppose in theory you could go back into the engineering menu to change to your one station.
Old 12-04-2013, 05:37 PM
  #255
dmighty's Avatar
2010 E350 Sport
I got the software update. can somone check and confirm the software version
Old 12-04-2013, 05:38 PM
  #256
timurik's Avatar
e350
Yes, that is correct. And there is a big number of stations you can choose from. But don't change the station, since you will lose this station and switch to the preview mode.
Old 12-05-2013, 11:28 AM
  #257
timurik's Avatar
e350
Actually, never mind my previous post. You can have 60 channels or so and you can change them the way you want and no hack are needed (I think it's a standard feature on every car equipped with satellite radio).
Old 12-05-2013, 12:34 PM
  #258
dmighty's Avatar
2010 E350 Sport
Tired the Bluetooth phone with a note 3 and it worked perfectly.
reconnects after a restart. So I guess its something with my phone.
no worries, as I am expecting the note 3 this week.
Old 12-07-2013, 01:24 AM
  #259
FastE's Avatar
2020 MB-AMG GLC43
Can you explain what you mean here? My car doesn't have free satellite radio. Does the engineering menu above do a workaround or not?
Old 12-07-2013, 09:01 PM
  #260
timurik's Avatar
e350
I had those 60 channels for 2 days and now they are gone all of a sudden. I didn't do anything special, was just browsing my engineering mode and got into audio option, where I selected satellite radio and, to my great surprise, it started to work. Well, now it doesn't work. I really liked the jazz radio there (watercolors).
Old 12-07-2013, 09:30 PM
  #261
chrisvr6's Avatar
lexus gx470
Where in the engineering mode menu?
Old 12-08-2013, 06:16 PM
  #262
chrisvr6's Avatar
lexus gx470
I can't find anything in the engineering menu that has to do with the satellite settings.
Old 12-10-2013, 12:23 AM
  #263
timurik's Avatar
e350
I believe it was under 3.12. It's not just the satellite radio, it fm, am radios as well.
Old 12-19-2013, 04:32 PM
  #264
dmighty's Avatar
2010 E350 Sport
finally got the note 3 and my car back and it pairs with no issues.
Must have been my firmware or some other issue with my iphone.
Old 02-20-2014, 10:26 PM
  #265
RicanDoc's Avatar
2018 GLC 300 4Matic, '69 Nova 350
BT Audio stream
It won't work on my 2012 GLK. I tried turning on BT in engineering menu, resetting and nothing. Is there something else I'm missing? BTW I'm using a Samsung Galaxy Note 2.
Old 02-20-2014, 11:19 PM
  #266
Substance's Avatar
I am expecting delivery of my 2014 E250 Bluetec in april.
can I while driving...
enter address either typing or via voice into navigation?
stream music via BT from my iphone 5s/ipad air and/or galaxy s4?
thanks
Old 02-20-2014, 11:38 PM
  #267
Long3494Qut's Avatar
thanks
BT stream, yes! Typing addresses, no, but voice is possible
Old 02-27-2014, 07:23 PM
  #268
tk9
tk9's Avatar
2010 E350 Sport
Anyone know how to turn on climate display in comand?
Old 02-27-2014, 08:50 PM
  #269
LasVegasMike's Avatar
2011 E350 Sedan
thanks
As qtip mentioned you can enter in an address while moving by using the voice command, but not with the command click wheel.
You can however override that function by installing a device such as this:
http://www.mods4cars.com/sms/shop/in...ode=view&id=58
I installed it in my car and it was simple to do. This version goes in the passenger side foot well area so you don't need to remove the radio from the dash.
Old 02-28-2014, 03:58 AM
  #270
BenzV12's Avatar
W212 FL
Judging by your model year , there is no way you can turn it on unless you upgrade your Comand version 4.0 to NTG 4.5 .
Still , when you touch one of the climate control unit buttons you can be able to see A/C display for a limited time only .
Old 04-01-2014, 08:08 AM
  #271
tinanikunj's Avatar
2010 E350
2010 E350 enable BT streaming worked with my Galaxy S4 in less then one minute
Originally Posted by jinx420hat
Alright guys I'll do my best at this... (BT=Bluetooth)
-End Call + # + 1: opens Engineering Mode
- HU Settings
- HU Parameter
(the following are the settings I put them in)
(1) BT contact plate: Not Installed
(2) LCT: Installed
(3) BT audio: On
(4) Audio Aux: Off (greyed out: not an option)
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
-pull command wheel down
- system reset
- reset - yes
- go to audio, then go to the audio tab again to bring up the drop down menu of audio options, select BT audio and activating audio device comes up, then the audio streaming screen
I have included screen shots of all the important steps (sorry for the poor quality but it was night time and the flash on my phone kept going off) Let me know if I need to clairfy ne thing.
Old 04-01-2014, 02:32 PM
  #272
axhoaxho's Avatar
thanks
You can use voice to input address while driving, and on the 2014 you can say the whole address at once, like "123 Main Street, San Francisco" without inputting city / street / house number separately. I have tried it a few times, and it actually worked very well.
Old 04-22-2014, 04:02 PM
  #273
BrianE's Avatar
2013 C250 Coupe, 2013 C250 Sedan, 2004 Ford SVT Cobra, 2002 Toyota Tacoma 4WD
Having issue with dealerships and COMAND upgrade
I have a 2010 E350 and I did the hack to get the BT to work; it works when I de-authorize my iPhone 5 and re-enable it like everyone else in this thread. I contacted two different dealers (MB of Fayetteville and MB of Cary) and both of them said that there's no update to the COMAND for my car. Has anyone else had this same problem with getting the dealer to do the update? I had one SM say that he can't just arbitrarily update my system because I want it updated, is this the case? Thanks in advance
Old 04-22-2014, 04:40 PM
  #274
thefisch's Avatar
2011 E550 P2 4M Sedan
I wonder if that works on comand 4.0 in my 2011. Will have to try it.
Is there any way to set a default city like you can for state? Is there a way to correct the street after you've selected one? I keep having to go back to the beginning and enter the city again.
Old 04-22-2014, 05:08 PM
  #275
thefisch's Avatar
That product does look easier to install. How long did it take you? Any install surprises or operation reliability issues?
Quick Reply: Does anyone know of any cool hacks for the new E class?
