W212 Round Fog Lamps
Old 02-18-2010, 09:30 AM
zazqqqq's Avatar
W212
Thumbs down W212 Round Fog Lamps
My W212 does not have the hocky-stick LED on the front but 2 round lamps on each side below the front bumper (A total of 4 round lamps, I think 2 of them are fog lamps). When I turn on the Fog Lamp function, only one of the round lamps on each side would lit. Does anyone know what the function is for the other 2 round lamps? Or how to turn them on? (I have tried all functions incl. daytime driving lamps, turn lamps...etc.)
Old 02-18-2010, 10:16 AM
Diesel Benz's Avatar
Try daytime running lights at daylight, you should find which lights come on.
Old 02-18-2010, 03:12 PM
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
Two are DRL's and two are fogs.
I found a business with a plate glass window down to ground and turned on all my light functions to see what they look like.
In my E350, you cannot turn on both DRL's and fogs because the headlights have to be on to turn on the fogs and this turns off the DRL's.
Old 02-18-2010, 04:42 PM
OAG
OAG's Avatar
E350 LUX 4M P2 D+
Yes it is a Govt Rule (something like no more than 6 lights can be turned on in the of the front of a vehicle (unless it is an emergency vehicle)).
Old 02-19-2010, 04:14 AM
zazqqqq's Avatar
W212
I turned on the daytime running light function and the dipped-beam headlamps come on (the ones next to main-beam).
Could the round lamps be turning lamps or cornering lamps?
Old 02-19-2010, 07:33 AM
mg-E550's Avatar
2010 E550 4matic, 2008 MDX, 2011 335i Vert
cornering lamps in my e550 w/ the hockey sticks are built into the headlight assembly in the interior side of the main headlight housing. Guess that's a weak description but hopefully you get the point.
Old 02-19-2010, 09:04 AM
silberrosa's Avatar
The inside pair of lights are fog lamps which are actived by pulling the h/l switch out to the first detent position. The outside pair are absolutely DRL which are acitvated via the instrument cluster. Turning lights are only with the Bi-Xenon lights and this light comes from the inside corner of the main headlamp unit.
Old 02-19-2010, 11:09 AM
zazqqqq's Avatar
W212
Weird..When I activated the DRL function via the instrument cluster, the inside pair of headlights (the diamond shape ones) went on. I wonder if anyone with the same model could show me a photo of his/her DRL goes on?
Old 02-19-2010, 11:15 AM
zazqqqq's Avatar
W212
Here is what happened when I turned on the DRL via the Ins. Cluster.
Old 02-19-2010, 11:26 AM
ipp
ipp's Avatar
W166 ML350 BT
Where are you located? Are you having the light switch in 'A'-mode?
Old 02-19-2010, 11:41 AM
zazqqqq's Avatar
W212
Yes. 'A' mode.
Old 02-19-2010, 01:07 PM
I have those led-lights and cannot test the same. Perhaps I could test if those inner lights come on somehow alone (that should be the case with parking lights only on).
Old 02-20-2010, 10:53 AM
zazqqqq's Avatar
W212
I wonder if someone could make a quick call to a dealership and get the answers?
Old 02-20-2010, 11:02 AM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Let us know what they say when you call them.
Old 02-20-2010, 03:41 PM
dmikim's Avatar
E350W
Is it possible to change the round fog lights to L shape LED DRLs?
Old 02-20-2010, 10:27 PM
zazqqqq's Avatar
W212
I called the dealer in Cape Town and they don't know. I then made an int'l call to M.Benz UK....I hung up after the customer service lady asked me the 20th questions.
Old 02-21-2010, 02:45 AM
Any chance that those lights could be forbidden in South Africa and the car would be coded differently than for other markets (instead of just incorrect coding for your car, obviously your car is not behaving like others that we know of)? How do other W212 cars behave and what about those with LEDs?
Old 02-22-2010, 09:01 AM
zazqqqq's Avatar
W212
This is the xxth email I got from the excellent, speedy MB Customer Service. For a simple question, wasted so many days, still gets no simple answer.
19th February 2010
Ref: HM-1-1301019929
Dear Mr Smith
Thank you for your recent e-mail.
To enable us to provide you with an appropriate response to your query, we would be grateful if you would provide us with the chassis number and registration number of the vehicle concerned, along with your full address and telephone contact details.
If you can forward this information to us then we will be happy to provide you with a full response. We look forward to hearing from you.
Yours sincerely
Helen M.
Customer Service Representative
Mercedes-Benz Customer Assistance Center Maastricht N.V.
Gaetano Martinolaan 10
NL-6229 GS Maastricht, Netherlands
Phone No:
00800 9 777 7777 (international freephone)
0207 660 9993 (charged at national rate)
mailto: CustomerService.UK@cac.mercedes-benz.com
Old 02-22-2010, 12:24 PM
This is a standard request at the forum too.
Old 02-23-2010, 10:26 AM
zazqqqq's Avatar
W212
At least this forum is more friendly. At first email, I gave them my VIN, then there came the second email asked for Reg #, I gave them my no. in S. Af which makes no sense in UK, then they sent the same email again which drove me nuts,,,,,
Old 02-23-2010, 12:26 PM
El Cid's Avatar
I can only speak for my E350 USA model with P1 package (four round lights). If I enable the DRL's, and it is normal daylight, only the DRL's come on. However, enabling the DRL's also turns on the sensor for the head and tail lights even if switch is in "O" position rather than "A".
Therefore, when light level drops to a certain level, the head and tail lights come on. Guess this is so people will not try to drive with just DRL's. My lights come on every time I drive into a garage.
BTW, I have had great service from MB USA in answering my quetions, but sometimes takes several days. All they need is VIN (so far).
Old 02-24-2010, 08:50 AM
zazqqqq's Avatar
W212
Originally Posted by El Cid
I can only speak for my E350 USA model with P1 package (four round lights). If I enable the DRL's, and it is normal daylight, only the DRL's come ....
Thanks for the great clarification. So, just a separate question: Do you enjoy having the 4 round lamps so far or you regretted not getting the L-shaped LEDs in the first place?
Old 02-24-2010, 11:07 AM
El Cid's Avatar
Cool
Very much prefer the four round ones over the L shaped/hockey stick ones. To me, it is a more "classic" look, which is another reason why I got the Luxury version. It has different shape to the bumper cover and a different grill.
Also, the L shape only comes with the P2 package and there were several things with it I did not want for the price M-B charges.
Old 02-24-2010, 11:51 AM
ipp
ipp's Avatar
W166 ML350 BT
Since you can't have xenon and the four round fogs they are a big no-no to me. A car in this segment must have xenons.
Old 02-24-2010, 01:01 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
Now, really.
The LEDs come in a package with HID versus halogen main lighting, and preferences in that respect are signficant while "opinions" regarding leds vs 4 round lights are solely asthetic, as there's no lighting that you'll ever notice from the driver's seat. Is it really just about "looks?"
Quick Reply: W212 Round Fog Lamps
