E550 Airmatic Sports Setting
Old 05-14-2011, 09:44 AM
Tjdehya's Avatar
2023 EQS 580
Originally Posted by 220S
Pay attention. I was purposely referencing ROW documents from Daimler's global media website and nomenclature, not USA specs from MBUSA.
Your copy/paste that you are referring to is only for the coupe and cab and the C Class (option.) The dynamic handling package is not an option on the W212 sedan RWD and 4matic in the USA.
We are talking about the W212 sedan here......
Hey genius take a look at what I highlighted... PAY ATTENTION! All I was pointing out was the "all at the touch of a single button" in relation to the fact that a "single button" changes both transmission and suspension.
I guess you are not smart enough to figure that out.
Sux to be u.
Old 05-14-2011, 01:07 PM
hyperion667's Avatar
Received 3,351 Likes on 2,807 Posts
2012 CLS63
jeepers
Old 05-14-2011, 03:34 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Not sure how old Tjdehya is or if it's just his meds, but I'll try to ignore it.
Nonetheless here are the details on this button 'confusion.' And it is confusing due to nomenclature in various markets and the availability. Even Edmunds Inside Line took time to try to explain it in the USA C Class versus the ROW C Class (link is at the bottom of the post.)
And it's all spelled out in the Daimler Global Media site.
In the USA you have two suspension choices in the E350, sport or luxury. There's no suspension button and you buy one car version or the other. That's just how it's marketed. Both models are active systems and not adaptive. With the E550 you get Airmatic. It has ADS (adaptive) and with two suspension settings , comfort or sport (it used to have three settings: comfort, sport I and sport II.) On both the E350 and the E550 there is an economy E (used to be comfort C) and sport S button for the transmission (and only the transmission) that lowers shift points and starts the car out in 2nd gear.
In the ROW, things are a bit different. You can get Airmatic in a lot of models including the E350. But in the non-Airmatic they have also a continually variable, dynamic handling, advanced agility control (or whatever the nomenclature is called depending the country it's marketed in) adaptive suspension mode button in the car. In addition in the Airmatic versions there is also ADS. So, in ROW you have the comfort and sport button that affects both the transmission and suspension, and there is also the ADS setting. That's why the Australian owners manual that WGB posted says the C - S button affects both "engine and suspension characteristics" and explains it in detail (p. 107) Diesel Benz also showed the Euro owner's manual version.
In the USA, the coupe and cab (convertible) also has a single button (marketed as agility control suspension in the USA) as an option on the E350 and standard o the E550. And the later C Class, too (which the coupe is based on.) This option is in the appearance package option for $1900 extra.
btw, some of the non-photoshopped imagery that the MBUSA website uses (video clips and some photos) are from ROW models. When they show the suspension video in the "explore the E350" section, they talk about sport and comfort but show the interior button of a ROW E500 with Airmatic in the video clip. So beware that some of the visual info is not precise.
fwiw, here's an explanation of the difference between USA and ROW (in respect to the C Class) as explained by Edmund's Inside Line: http://blogs.insideline.com/roadtest...y-control.html
"That C/S button at the bottom of the PRND indicator has nothing to do with the car's suspension. No doubt long-time Mercedes-Benz fans will know it only changes the behavior of the transmission. Why the confusion? The problem is that European markets are already enjoying genuine adaptive suspensions on their C Classes. The working name for that feature, which our market will get sometime next year, is Advanced Agility. Online Mercedes-Benz forums are already filled with pages attempting to clarify this nomenclature. It seems that even some U.S. Mercedes-Benz sales staff are telling customers that the button next to the shifter controls the adaptive suspension. When it does arrive in the 2009 C Class, the button controlling truly active dampers will be at the base of the center stack."
Anyway, hopefully it all makes a bit more sense (?)
Old 05-16-2011, 02:43 AM
Super Moderator Alumni
Nola's Avatar
Audi A5 Sportback + Cannondale Prophet
Sux to be u.
Tjdehya, you have PM.
Old 02-20-2017, 04:42 PM
Chris Lora's Avatar
2006 Infiniti M45 2012 E63 AMG P30 Pkg 2016 Honda Accord Sport
Exclamation What does this Button DO?
thinking of buying a W212 E550 just curious what does the button under the comfort/sport suspension button do?
Old 02-20-2017, 04:46 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Vehicle level, see image.
The following 2 users liked this post by konigstiger:
Chris Lora (02-21-2017), flipstah (02-21-2017)
Old 02-20-2017, 05:02 PM
  #32
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Attachment 349383
To add to Konigs response. It raises the vehicle up substantially. I'd say just from eyeing it that there will be a 2-3 inche gap in the wheel well. This allows you to get thru flooded areas or to get over an embankment that you otherwise couldn't traverse. There is a speed limit that it will automatically lower back to C or S. Just going off of memory I know it was 35 mph or less.
Old 02-20-2017, 05:07 PM
  #33
thefisch's Avatar
2011 E550 P2 4M Sedan
just tell your passengers it's an ejector seat button.
Twinship22 (09-17-2021)
Old 02-20-2017, 05:38 PM
  #34
Tonyb203's Avatar
2010 mercedes benz e550
That's the air ride up and down
Old 02-21-2017, 04:23 PM
  #35
flipstah's Avatar
2010 E550 4Matic
Vehicle level, seed image.
Stwoage? What is this, written by Elmer Fudd?
I kid.
Old 09-05-2021, 08:48 PM
  #36
propellerhead's Avatar
2010 E550 Sedan
Thanks to everyone for the awesome input, the arguing not withstanding.
UPDATE: I swapped the front and rear air lines at the solenoid to see if the rear would drop the next morning like the front does, or if the front shocks are bad. In doing so I found the o-rings to the front lines were no good. I tightened them down a little more and it's been holding for about 7 hours so far.
One mechanic wanted 5k to do the shocks, dealer wanted 6k, makes me wonder if they know it's things like this and they like to say its big ticket items and then fix these little things while they are at it. In any case, I hope I just avoided buying 900 dollar shocks.
Old 09-05-2021, 09:21 PM
  #37
bmwpowere36m3's Avatar
Received 1,004 Likes on 675 Posts
'11 E350, '11 E550, '98 M3, '95 E320
The o-rings don't typically go bad and/or the connectors suddenly being loose... either a PO was messing with it due to leaks or when you swapped them front-to-rear you didn't tighten the connections. Not that they need much, as they can easily strip the nylon housing of the valve body or spring cap/ends.
Old 09-05-2021, 10:22 PM
  #38
2010 E550 Sedan
These had a section missing like someone snipped a piece out of each one.
Quick Reply: E550 Airmatic Sports Setting
