4MATIC Staggered Wheels
Was discussed here many times. Short answer - yes you can. Are you gaining anything (for 350) by doing so - no, you do not (unless you already have wheels/tires from RWD that you want to "reuse"). For details, do a search, please.
S550 4matic
I did a search..... nothing for 2011....the "gain" is the look...I was asking if any one was actually doing it and what size there set up is... so relax.... I'd like proof that it works, not just some one that "thinks" they know
Listen newbie, YOU relax. I'm no "thinking" - I'm a "professional" in this field and I "know". You want "proof" - I've done it on a multiple W211 and W212 4matic cars with no issues. You do not search for "2011" (FYI cars came out for '10 MY in 2009), search for exactly your topic in W212 forum. You will get a number of hits, then do some DD. For starters, search my posts - you'll find what you want. I do not know why I even bother helping someone with attitude like that. And the only "proof" is when you do it yourself (preferably many times) and not what you read on MB. Good luck reading. Capish?
Xhuliano.m (06-07-2021)
S550 4matic
Newbie? Thats funny.... Look genius if you dont like what I post ignore it...I still havent found any one that says they have staggered on their car and what tire size they are using... most of the threads just speculate. Just wondering if any one is ignoring the claim that the wheel circumfrance has to be the same front and back. Why would I experiment if its going to f*ck my car up?...
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
For the record, if M-B states not to do it, I wouldn't do it. Too complex and drastic a situation to play with. Not to mention, if something does go wrong, and even if you do put the regular wheels back on (to try and fool them into thinking that you never changed the wheels), one has to wonder as to whether they can find out that you used a non-staggered setup.
Received 3,352 Likes
2012 CLS63
https://mbworld.org/forums/e-class-w...n-options.html
https://mbworld.org/forums/e-class-w...ally-here.html
https://mbworld.org/forums/e-class-w...res-setup.html
https://mbworld.org/forums/e-class-w...hotoshops.html
You can also search through the W211 forum. I hate to go through this argument again but I have never seen anything where MB says "not" to put staggered wheels on a 4matic. Mercedes has sold 4matics with staggered wheels before, just because they don't do it anymore does not mean that they say you can't/shouldn't. The largest difference in diameter MB has rolled a 4matic off the production line was .2% so I used that as my limit. But you should aim to get as close to 0% just for peace of mind. IMO
11 GL350 BT | 11 E350 Estate
Staggered wheel sizes not compatible with 4MATIC all wheel
drive vehicles. Must use front axle size on both front and rear axle.
Personally I don't think there's anything wrong with going staggered on the 4Matic. But to answer your question regarding MB advising not to go staggered wheels on their 4Matic vehicles, here is a quote from the MBUSA W212 E-class accessories catalog:
To prevent another repeat thread this will be my last post in this thread.
2012 CLS63
if anyone DOES ever burn up they're case I wonder if we'll ever know about it.....or read about it......lol....
seems like it'd be to embarresing to post about if you did......lol......
how many miles do you suppose it would take for the transfer case to start
showing the signs?
showing the signs?
raja777m (08-27-2018)
2012 CLS63
Tjdehya
Tjdehya
Do you guys realize the C300 4matic Sport comes STOCK with staggered wheels/tires?
Fronts are 225/45R17 (24.97" outside diameter)
Rears are 245/40R17 (24.72" outside diameter)
That's a 1/4" difference from front to rear.
Ummm if there were a problem running staggered, would MB be doing it?
for bapkc
Ok 2013/14 E63 AMG comes with 4matic set up and uses staggered wheels and tires they are 255/35/19 F and 285/30/19 R so yes u can if u are going to run 19s use 245 45 19 front 275 30 19 rear mak sure front wheel no wider then 9inch otherwise it will rub when turn rear u can go up to 10.5 but thats max and little risky I have 9 front 10 on the back no problem more questions hit me up on snh1985snh@gmail.com
Can I use this "staggered wheels & tires" size for my 2011 E350 4MATIC Wagon? Was recently in an accident were I ran over a big block of something & bent all four (4) of my wheels which are OEM 17".:
SCW#: MBZ-WWH-85240PVD
Wheel Information
Brand: Factory, OEM
Finish: Black PVD
Size Front: 17x7.5 +45mm
Size Rear: 17x8.5 +49mm
OEM Part# Front: 2074010702
OEM Part# Rear: 2074010202
Reference# Front: 85238
Reference# Rear: 85240
Tire Information
Brand Front: Michelin
Brand Rear: Michelin
Model Front: Primacy MXM4
Model Rear: Primacy MXM4
Size Front: 235/45/HR17
Size Rear: 255/40/HR17
Tread FL: 80% 8/32
Tread RL: 99% 9/32
Tread FR: 80% 8/32
Tread RR: 99% 9/32
Thank you for the assistance.
Wheel Information
Brand: Factory, OEM
Finish: Black PVD
Tire Information
Tread FL: 80% 8/32
Tread RL: 99% 9/32
Tread FR: 80% 8/32
Tread RR: 99% 9/32
Sorry to add to this post but this is the first to come up in my search. I am wondering if after a couple of years since BAKPC originally posted if he had any problems with his diff? I'm driving a 2008 E550 and it seems that the wheels that I really like are all staggered, mostly used , so there is no option to get the same size. Thanks to all that have gone before me.
will this work on a 2011 c350 4matic? I want the Vossen VFS1 19x9 / 19x10 setup.
Received 1,730 Likes
1922 Ford Model T / no OBD
I've been educating car owners about tires rpm (rounds per mile) for longer than this thread last, but it is not getting through for some reason.
So once again >>> the car doesn't see if the wheels are staggered. All the sensors see are wheels rpm.
MB never disclosure the tech data on the issue, but rule of thumb says that matching the tires within 3% is good, when 5% seems to be border line, where CC and ESP start the discotheque
