Hold function?
Don't know how strong a braking, though.
the hold on, if you got romped from behind......
so it would stay engaged? seems like it would or why have it? aside from
the nice rest for the foot......
I also recall reading somewhere that the hold could put extra, un-needed
stress on the calipers or pads? or am I nuts?
Your car does go through the intersection.
The seatbelts clamp down on you like a strong wrestlers bear hug.
Your head gets jolted from the neck pro headrest popping forward.
The emergency flashers automatically go on. You unlatch the seatbelt's chokehold in order to breathe.
In 15 sec a voice comes through your car speakers stating 'deployment of MB SRS devices was detected. We have your location, do you require police and and ambulance?' You say 'yes'.
You stagger from you car, shaken, but uninjured.
In two minutes your wife calls you from work and says he water broke. Later that night you become a dad. And, you're glad you bought a Mercedes.
That was a hell of a day -- the memory of it still shakes me up.
To answer the question, both you and HOLD will disengage the brake in a rear impact, but given how hard HOLD clamps on the brakes and its delay in disengaging, it will likely hold you in place better than your foot.
In a mild rear end collision, your foot will not be able to keep the brake depressed. a 10mph impact makes your 10lb head weigh roughly 170lbs in just 60 milliseconds. The average human leg weighs about 20lbs so in a 10mph impact, your leg alone is experiencing the same 15-20g's as your head. This means that your leg weighs about 340lbs!!!!
That is a worst case scenario. There are tons of mechanical variables. But you get the idea.
Seriously; it doesn't put extra stress on the calipers/pads. If you have the hold function activated it is like you pressing the break pedal. Up to a certain point the more you press down on the pedal the more firmly the calipers grip. After a certain point the calipers are gripping at a 100% so it is irrelevant if you keep on pressing the pedal harder, the calipers can not grip any stronger. When standing at a red light you can hold the break pedal as you would normally with one foot and the calipers are gripping at 100%. You could also stand on it with both feet and the calipers would still only grip with 100% (like if you would do with one foot only).
And if you want to become a know-it-all also
http://www4.mercedes-benz.com/manual...97e38685.shtml
I assume you must be fully stopped?Do you need to use two feet?
this will be quite useful when stopped on a grade. Another "hmmm" moment for sure.
