Old 06-24-2015, 06:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting
Print Wikipost
My HID Install with DIY Instructions
Rating: Thread Rating: 2 votes, 4.50 average.
Old 04-13-2013, 05:03 PM
BM2BZ's Avatar
w212 E550
Originally Posted by Nuru
Did a dealer tell you that the install of the lights would void your entire car's warranty or just for the headlamps and associated systems?
they wouldn't get into the details unless you ask which i didn't .
Old 04-18-2013, 04:46 AM
5Hundred's Avatar
2014 C63 P31 Coupe; 2022 R8 Performance RWD; 2018 Stelvio Quadrifoglio
Have the insides been fogging? Both mine (P1 stock halogen) and my friends (e63) fog from the inside of the headlights
Old 04-18-2013, 06:22 PM
Nuru's Avatar
S350 BT 4MATIC
I asked MBUSA and they said it only would void the warranty on the portion of the car they can prove is affected - which they indicated is kinda tough to prove unless it is something very obvious. So if your lighting circuitry gets fried, then you would have to pay for it yourself even if the car is still under warranty.
Old 04-19-2013, 03:08 PM
Tpajohn's Avatar
2010 E350
I recently installed the morimoto hid's. I went through the headlight compartment (plastic housing containing parking lights, high beams, and headlights), and placed the ballasts and all inside that compartment. Took about 40 minutes total without taking off wheel well or anything. The driver side is a PITA but is doable.
Old 04-22-2013, 01:47 AM
joeyz400's Avatar
2012 E350
Hey guys I just installed 6000k parking LED's and I'm putting a 6000k HID kit on my 2012 E. My question, is there a way to change my straight LED strip fog lights bulbs to match the 6000k bulbs? They look yellowish 4300k.
Old 04-24-2014, 11:16 PM
The Ryno's Avatar
2011 E350 Bluetec
COuld you elaborate a bit for me? I am about to install this weekend and am totally open to an easier method! I have installed many of these kits over the years on other makes, but have never had to remove a wheel. If not going through the wheel well, how do I access from the top? ALso, were you saying you just stuffed everything (wires, plugs, etc) into the original light housing? I have heard others say this as well. I appreciate any more detail you might provide. Thanks!
Old 04-25-2014, 01:12 AM
  #32
mystery905's Avatar
2012 E300 4Matic
Nice job OP!
Fortunately, up here in Canada, HID is standard on all E classes, so I don't need to use your procedure.
Old 09-05-2015, 02:44 AM
  #33
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Please tell me how you replaced the little bulb in the high beam housing.
I just installed similar Xenon kit on my car and want to replace the little bulb as well.
Thank you
Old 09-05-2015, 11:47 AM
  #34
SPONSOR/MBworld Guru
AZN Optics's Avatar
Thank you
That's a 194 wedge LED. You'll need canbus units. Plug is accessible from the rear.
http://www.aznoptics.com/index.php?m...products_id=95
Old 09-05-2015, 12:19 PM
  #35
When you say Canbus unit, do you mean I will need a resistor?
Old 09-05-2015, 01:12 PM
  #36
AZN Optics's Avatar
Our units have built in resistors. Plug and play
Old 09-05-2015, 01:36 PM
  #37
Can you please send me the link to your unit that you are referring to.
Thank you
Old 09-05-2015, 07:20 PM
  #38
AZN Optics's Avatar
Thank you
Linked it few post up
Old 11-12-2015, 01:34 PM
  #39
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Originally Posted by amaycg
Thanks for all the replies! I'm glad I was able to help
How's the kit holding up? And does it now come with the correct clips?
Old 05-01-2016, 02:40 PM
  #40
Mj3xt's Avatar
2014 Mercedes e350 4matic
2014 e350... Bought the 2015 xenon headlights from hella
Hi
I recently purchased a 2014 e350 but wanted to upgrade the headlights lights to the 2015-2016 xenon lights, however after purchasing the control ballast and programming it we realised the headlights do not come on😳.
Secondly, unlike the 2009-2014 model which have the easy access cap behind the headlights to change bulbs, the 2015 - 2016 model has no 'cap'opening for the headlights in order to check whether there are any bulbs in .
Can anyone help me with more information on how to solve this issue?
Old 05-09-2016, 11:19 AM
  #41
shak's Avatar
Originally Posted by AZN Optics
Any idea where to find a pair? Your side it OOS.
Old 05-09-2016, 12:28 PM
  #42
AZN Optics's Avatar
That's because we recently released a refreshed model design v5.1:
http://www.aznoptics.com/index.php?m...roducts_id=112
We regularly update our models every year or so with newly released LED technology to ensure our customers received the latest and greatest
Old 05-17-2016, 10:08 AM
  #43
shak's Avatar
5) It's time to secure the HID bulb. the H7 bulb plugs into the retaining clip and into the female connectors. The original H7's retaining clip sits behind the H7 bulb and the clip's two metal extensions are secured onto the housing's two metal flaps. However, since the female connectors (the black connector box) is removed from the retaining clip and the bulb, you need to secure the HID bulb with JUST the retaining clip, not the black connector box. This is somewhat obvious because unlike the stock H7 bulb which has two plug prongs on the bottom of it, the HID bulb is attached to wires.
Since the HID bulb was wires that come out of it and the retaining clip needs to attach to the metal base of the HID bulb, the only way to easily secure the retaining clip would be to cut a slit on the side of the retaining clip to let the wires easily pass through to the open center of the retaining clip. You could then push the retaining clip up over the wires to the bulb.
Since the car is leased and will be going back in about a year and a half, I DID NOT WANT TO MODIFY THE ORIGINAL BULB RETAINING CLIP (the clip with the two metal extensions that get caught behind the housing's metal flaps), so I decided to buy another set of aftermarket clips:
http://store.ijdmtoy.com/Audi-BMW-Me...s-p/aa1047.htm
I modified the stock bracket, but it did not look like its going to hold the bulb in place. It felt a little lose to the touch, nothing like OEM one.
Has anyone had any luck with these aftermarket brackets? I really don't want my headlights disconnecting while driving.
Are there any better alternative clips?
Old 05-21-2016, 11:24 PM
  #44
Killertraylor's Avatar
2013 E350 Bluetec
I had the same issue with the stock clips - took me 30 minutes on each side to twist/ bend/ alter those into place - the morimoto HID bulbs have a bigger plastic base than the stock bulbs. Morimoto should include a metal clip that fits the H7 HID bulb with the morimoto kit and it would be a 45 min install instead of a 2 hour install. I took the wheel off on the passenger side too knowing it would be crazy difficult to get that metal clip to turn into place. Looks great though - very happy with the end result and thankful for the OP's write up.
Old 08-01-2016, 09:54 PM
  #45
Heisenberg5070's Avatar
E350 Sport
does anyone recommend drilling a hole underneath thr housing instead of the dust covers?
Old 11-22-2016, 07:16 PM
  #46
KracktheRipper's Avatar
E350
2 Questions
I'll make this short and sweet.
1. I bought a 2011 E350 in May and from what I have read so far I believe it is a W212 body style. How do I tell if it is a P1 or a P2?
2. Do you know of any websites that tell exactly which headlight colors are legal in the state of Virginia?
Thanks in advance for any help!
By the way, amaycg you did an amazing job detailing this procedure! I am going to use this within the next couple of weeks to do my install.
Old 10-26-2017, 12:50 PM
  #47
Anthony199's Avatar
e350 2012
Originally Posted by kpma28
I finally did mine too. This is what i installed http://www.theretrofitsource.com/pro...oducts_id=3893 6000K 35W. Everything fit inside the headlight so no need to drill.
Hey! Since it's been a while after you replaced you bulbs, I was wondering if you had any issues with having the ballasts in your headlights? The heat of the ballast didn't damage anything?
Old 10-26-2017, 12:51 PM
  #48
Anthony199's Avatar
e350 2012
dust cover is cheaper to replace, and easier to seal around the grommet. Also easier to drill.
Old 10-26-2017, 05:24 PM
  #49
Mud
Mud's Avatar
2011 E-350 4Matic Sport
I've had the Morimoto 35w kit in my car for about 2 yrs now. Works perfectly. Bulbs used are 6k.
Also had to fiddle with the aftermarket bulb clips to get them to hold tight. Drilled the dust covers as mentioned above, used the wiring grommet and a bit of weatherseal tape. No issues with any dirt getting into the housings. That driver side is a pain lol.
Edit - in my case the ballasts are outside (below) the housings.
Old 10-26-2017, 05:31 PM
  #50
Anthony199's Avatar
e350 2012
6k is a better match with the drl than 5k right? Btw, i have a lot of questions about these clips but i didnt ask because I might be able to answer myself when i take a look at them. So are they like a metal bracket that folds down to hold the bulb? Or just something you would add to the bulb base to make it fit in the opening?
BTW, regarding that driver side, I've heard a lot of complaint about how difficult it is to handle, but it really very easy to do from the wheel well, no? I've watched some video and there seems to be more room to work with the headlight than from the passenger side...
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
Quick Reply: My HID Install with DIY Instructions
