AM Radio Reception
Old 07-09-2012, 05:14 PM
boater07's Avatar
2012 E 350
AM Radio Reception
Are most of you satisfied with the AM? I feel I get a lot more static than my
previous car with outside antenna.
Old 07-09-2012, 06:04 PM
CEB
CEB's Avatar
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
What mods do you have?
Old 07-09-2012, 08:11 PM
BPhillyBenz's Avatar
'11 350 4matic - '14 Stingray: Gone, BMW 530i, Porsche 944 Turbo, Porsche 356, Mitsubishi 3000GT
I feel your pain. My AM radio reception is awful. Still dig the car, however.
Old 07-09-2012, 09:21 PM
listerone's Avatar
2018 BMW 540d
Mine was horrendous too until I took it to the dealer.Can't recall for sure what they did...I think they mentioned some paint having been removed (too lazy to find the service write up)...but when they were done it was 1000% better.
Old 07-09-2012, 10:06 PM
boater07's Avatar
2012 E 350
What difference does it make? I have new W212. Do other models have different attenas?
Old 07-09-2012, 10:09 PM
boater07's Avatar
2012 E 350
Good to know. I will bring it up to dealer. Still to much fun trying all the extras
like sirius.
Old 07-09-2012, 10:37 PM
Zeee_Q's Avatar
C63, 335i
If your car has metallic tint on the windows, that could affect the reception as well
Old 07-09-2012, 11:16 PM
CEB
CEB's Avatar
Mods like metallic tint will adversely affect AM reception - as will some electrical mods. Accordingly, with a complaint of "poor am reception " the first question is always "what mods do you have?"
Old 07-10-2012, 09:13 AM
listerone's Avatar
2018 BMW 540d
Good to know. I will bring it up to dealer. Still to much fun trying all the extras like sirius.
I overcame my laziness and dug out the service writeup.It's hard for me to decipher but here's my best attempt:
(partial) quote: "...checked ground at antenna amp,it has high resistance. r+i amp found that mounting flange.Cleaned paint off flange reception ok now.used non time .50 to r/r antenna and clean paint off flange."
Not entirely sure what it all means but,as I said,the AM reception has been perfect ever since.
And I don't have any "mods" at all....mine's exactly as it was when it left the factory.
Old 07-10-2012, 12:56 PM
boater07's Avatar
2012 E 350
Thanks much. Don't know what mods I have either-other than P1,distronic+,
Parktronic, custom steering wheel, etc. Maybe rear view camera has an effect?-
but then again-it's not in the window.
Old 07-11-2012, 10:25 PM
CEB
CEB's Avatar
Sounds like you had a bad ground.
Old 07-11-2012, 10:28 PM
CEB
CEB's Avatar
Factory options are not modifications. A modification is something like tint that you (or someone else) do to your car after it leaves the factory. A mod includes stuff that the dealer does to the car - again like tint.
Tell us about your "custom steering wheel." What is it and who installed it?
The factory wheel has all sorts of electronics built in and could cause static if you're using something that wasn't made specifically for your model - That's a mod.
Old 07-13-2012, 06:33 AM
boater07's Avatar
2012 E 350
The factory wheel has all sorts of electronics built in and could cause static if you're using something that wasn't made specifically for your model - That's a mod.[/QUOTE]
option 289-Wood/Leather Steering Wheel-$590
Old 07-13-2012, 06:57 AM
CEB
CEB's Avatar
option 289-Wood/Leather Steering Wheel-$590[/QUOTE]
I can only assume that English is a second language and you don't grasp the difference between a factory option and a modification. Saying that you have a "custom" steering wheel means that you have a modification but it appears that you are saying that your "custon" wheel is really just a factory option.
Let me try this one more time.
Did you, your dealer or anyone else do anything to the car that wasn't on the factory order or that wasn't specifically designed by Mercedes for your car?
Old 07-13-2012, 07:47 PM
boater07's Avatar
2012 E 350
Did you, your dealer or anyone else do anything to the car that wasn't on the factory order or that wasn't specifically designed by Mercedes for your car?[/QUOTE]
I think you are carrying this beyond the ridiculous trying to make a point.
A 2 week old factory ordered car has had little time to make mods.
From your attitude, I suspect english is also your 2n'd language.
Sprechen Sie Deutsch??
Old 07-13-2012, 08:42 PM
CEB
CEB's Avatar
Sprechen Sie Deutsch??[/QUOTE]
Eigentlich shon, aber als Zweitschprache.
We do not know that the car is two weeks old and we do know that many people have their windows tinted immediately or have other modifications made either at the dealer or at another place.
Metallic tint is the number one reason for poor AM reception. The second most common reason is a bad ground caused by a nachbau of some sort of electronics.
Old 07-13-2012, 10:53 PM
boater07's Avatar
2012 E 350
Metallic tint is the number one reason for poor AM reception. The second most common reason is a bad ground caused by a nachbau of some sort of electronics.[/QUOTE]
Danke Schoen.
I now understand
Old 07-13-2012, 11:21 PM
CEB
CEB's Avatar
Gerne. Die vielen Jahre an der Uni Wien und Muenchen haben sich anscheinend ausgezahlt.
It could be a poor ground like Listerone had or it could be a loose or detached connection.Your dealer should take care of it under warranty with no issues.
Old 07-13-2012, 11:51 PM
boater07's Avatar
2012 E 350
Einbildung ist auch eine Bildung!!!!
A good suggestion was made long before by Listerene before your nonsense
Old 07-17-2012, 03:51 PM
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
For about last 20 years, no car I have owned (American, Asian, European) has had decent AM reception. Of course since almost all AM is now talk radio, I haven't listened to it in about 20 years so doesn't really matter.
Old 07-17-2012, 05:08 PM
listerone's Avatar
2018 BMW 540d
Some AM stations,particularly in larger cities,have HD subchannels today that sound pretty good.Some also have FM HD subchannels that sound even better.There's some talk radio that's worthwhile...and when I want music I switch to the 2000+ songs I've transferred onto the hard drive.
Old 07-17-2012, 05:26 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
My FM radio reception sucks after I installed my HID kit, but I don't really care b/c I'm a Sirius person haha
Just saying, HID Kits can also affect static.
However, the benefits of HID > FM radio reception for me
Old 07-18-2012, 04:04 AM
BenzV12's Avatar
W212 FL
HIDs effect static ? That's something new to me
I don't care whether or not AM reception sucks either lol
Old 07-18-2012, 02:12 PM
CEB
CEB's Avatar
Tint and electrical mods can easily affect radio reception. Normally tint will affect the AM portion as the AM loop antenna is in the rear window on most newer cars.
A bad ground may interfere with both AM and FM radio.
Making a mod and finding a new radio problem almost always means that there is a problem with the install and may only be the tip of the iceberg of future problems. Do yourself a favor and have the HID install looked at before you're stranded on the side of the road.
Radio reception is often the first sign of a more significant problem.
Old 01-08-2013, 12:13 AM
ORETEX's Avatar
2009 clk 350
AM Reception/window tint
I purchased my 09 CLK350 last yr and AM radio reception was worse than my daughter's 03 PT Cruiser. WTF. Dealer says it is likely due to heavy tint on rear window. Plan to remove tint from all windows and will post after if this fixes the problem.
Quick Reply: AM Radio Reception
