2014 tail lights retrofit ?
Old 06-19-2013, 02:29 AM
jayphan92's Avatar
2010 E63 AMG
Anyone planning on trying to retrofit the new 2014 tail lights?
They're both the same shape. Looks like its possible with all the right wiring harness.
Would love to do it eventually, wonder what the price of the tails would be
Old 06-19-2013, 12:13 PM
alanme123's Avatar
2012 E350
Get the clear taillights instead!! They look so much better!
https://mbworld.org/forums/e-class-w...er-needed.html
Old 06-19-2013, 12:17 PM
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
I not planning to retrofit the 2014 tail lights ... instead I'm retrofitting myself into a 2014 next month ...
Old 06-19-2013, 12:52 PM
E Classy's Avatar
BMW 5er
Old 12-19-2013, 02:26 AM
jayphan92's Avatar
2010 E63 AMG
has anyone done this yet, and know the costs? and what i need?
Old 12-19-2013, 02:39 AM
leapingpoint's Avatar
E-class
not as easy as plug 'n play.
wiring needs to be replaced as well.
Old 12-20-2013, 08:49 PM
hyperman51381's Avatar
201 E350
Angry Major failure, Breaks, ABS, SRS lights all came on
Got the complete 2014 set off Ebay and all the warning lights came on. Seems like only the outer lights is plug and play but the inner lights do not come on and the dash warning for Breaks, ABS, SRS lights all came on.
Old 12-21-2013, 02:29 PM
Yosheego's Avatar
2011 E550
Maybe a simple code/update might work, that's if the dealer does jt
Old 01-01-2014, 05:46 PM
diesel_power's Avatar
2011 E220 CDI
There are some cars that has been retrofitted with these taillights, so it's possible.
But I don't know anything about the process to get them to work properly. I'm guessing wiring and maybe a control-module of some kind (?).
I would definitely be interested if someone finds out what's needed.
Old 01-02-2014, 09:43 AM
C230Brit's Avatar
2010 E550 Coupe
Shame they are not plug and play. Just to be clear, the new style rear lights did actually physically fit the recess without any modification?
I thought I'd read in another members (person that upgraded the entire front of his car) post that the fit was not good.
Old 02-14-2014, 03:35 AM
eNNCity's Avatar
2013 E350
Has anybody looked into this? I'm considering getting the new 2014 tail lights to install on my pre-facelift 2013. What's required for wiring and harness?
Old 03-12-2014, 12:09 AM
alloutmk23's Avatar
2011 E350 4-Matic Sport
anyone chime in?
Old 03-15-2014, 09:22 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Up!!! I might buy a E63 and facelift it so any info would be great if your sitting on it.
Old 04-08-2014, 09:30 AM
alloutmk23's Avatar
I'll buy a set of rear tails soon and see what the issue is first hand. I would think that it wouldn't be too difficult to get them to work.
Old 04-08-2014, 09:43 AM
Me neighter,,
Old 04-08-2014, 10:52 AM
benyl's Avatar
'10 F150 FX4 SCrew. '14 S212S
From what I read, for the rear, you need new SAM units and specific programming. You probably need a VIN from a 2014 to get the SAMs programmed.
The only front retrofit that I have seen that is successful is on the Coupe. Haven't seen anyone do the sedan yet.
Old 04-08-2014, 11:00 AM
Tjdehya's Avatar
2023 EQS 580
Well now you have... https://mbworld.org/forums/e-class-w...ewel-20-a.html
Old 04-08-2014, 11:06 AM
benyl's Avatar
Those wheels....
I know the parts work (fit). Do the headlights work? Does distronic work? Fitting the parts is the easy part. The programming is the difficult part.
Old 04-08-2014, 11:08 AM
alloutmk23's Avatar
Yeah I also saw that and asked him how he did it, no response.
Old 04-09-2014, 01:22 PM
m0v30v3r's Avatar
AMG
I have one 2014 e class tail light which has a tiny crack line on the outer cover. I will sell it for $100 shipped in the lower 48
Old 09-01-2014, 07:11 PM
MERC_BENZ's Avatar
Any word on how to make this work?
Old 12-22-2014, 01:14 AM
hamooda_47's Avatar
2013 E300 AMG
no words still...
Old 12-29-2014, 10:51 PM
LandSeaAir's Avatar
2008 W204
At first I wasn't even sure if the 2014 lights would fit in the 2010-13 cars, but I guess they do.
I'm sure anything could be done with the right STAR tech. For the W204, the alternative to reprogramming the rear SAM was a convertor (probably with a bunch of resistors) that deleted all the error codes and made the lights work perfect. Its probably a matter of time till these convertors come out for the 212 along with a cheap replica of the 2014 lights.
Old 12-30-2014, 06:15 PM
nauticalx's Avatar
E550C
Agreed. I dont see why sam reprogram would be the way to go. technology is the same. leds lighting up. just a matter of the right input tying to the right output. converter would be best IMO. should be simple, could do it myself if someone would get us a pinout etc. not too difficult to get those lights to disappear if you fake the signal its looking for.
question is, anyone got a wiring diagram and pinout for front and rears?
im trying to do front as well but that will be much more complicated with active curve illumination and the change from Xenon to Led main light bulbs.
Old 12-31-2014, 06:16 AM
MrProxenon's Avatar
W212 E220 CDI EURO
sorry , there are shape diference on the tailights . They fit perfect with facelift rear bumper , otherwise there will appear a whole gap in the lower side . I remeber germans sells on ebay.de a plastic part to fill that gap ...and that small parts costed just 99 eur ( 135 usd ) only !
Quick Reply: 2014 tail lights retrofit ?
