Armrest console organizer
I have one also but the trouble is that it is a pain to get out once installed. It is to tight of a fit and if you need to get at stuff under the tray it is a pain.
I ordered this tray http://www.ebay.com/itm/272416785495...%3AMEBIDX%3AIT because its ebay listing clearly indicates that it fits the 2014 E-Class.
I received that tray and installed it. It fits perfectly and works well. No modifications are necessary. However, if like me, from time to time you need to quickly pick the tray up to access the items underneath it (in my case, my iPod), I modified it by drilling two holes in the center of the center divider and looping a black wire tie through these holes to form a small loop that I can easily grasp with one finger and pull the tray up. Be sure to glue or tape the back of the wire tie to the underside of the tray so that the loop is the right size and won't move.
__________________
__________________
__________________
__________________
2015 Triumph Thunderbird LT 2008 Dodge Ram Bighorn 2011 Mercedes Benz E550 Sedan
#32
Peter, I just stumbled on to this thread and saw your pic of the center storage. I too saw these on eBay this evening. Do you think these will fit onto a 2016 w212? Are the compartments different from your model year to mine?
nightspd (11-27-2019)
#33
Received 1,718 Likes
2016 E350 Sport
Peter, what Joe is asking is what USB configuration do you have in your 2015 Wagon? The products available differ depending whether the console has the single USB port in the back wall, or the dual USB ports on the right rear side. Which USB does your 2015 have? Thanks.
Joe Alonso (12-03-2019)
