19x9.5 38et and 19x10.5 32et Will this Fit???
Old 06-12-2014, 07:42 AM
threeMBs's Avatar
Only MBs - the best or nothing
Old 06-12-2014, 07:47 AM
threeMBs's Avatar
Old 05-10-2017, 05:17 PM
berti_00's Avatar
2016 Cls63s AMG
19x8.5/19x9.5 ET35 all around
would this work??
would be lowered on vogtland springs
Old 05-11-2017, 10:07 AM
blegthbloo's Avatar
2013 E550 4Matic
I think as long as it doesn't go below ET32 (at those widths), you should be fine. But I'm not an expert.
Old 05-13-2017, 10:30 PM
meccamilla's Avatar
2013 e550
im running 19x10.5 with 255/35/19s all around
Kai Takase (06-24-2019)
Old 05-15-2017, 03:27 AM
Ed99's Avatar
E63s AMG
Running 19x11 in the rear and they fit nicely.
Old 05-19-2017, 02:17 AM
  #32
Style_Front's Avatar
ez-go
Can you guys with wide square set ups post pictures?
Old 05-27-2017, 05:01 PM
  #33
Hsg08's Avatar
MB W212, MB W218, BMW F06, BMW F48
My car is 4matic and lowered on H&R springs. I'm currently running F19x8.5+23 and R19x9.5+26 wrapped on F245/35 and R275/30. So far so good, the front only rubs when I hit a big dip or something.
OP's ideal wheel spec should be fine as long as you don't run bigger than f245/ r275 .
scrowley (05-27-2017)
Old 05-27-2017, 11:53 PM
  #34
Ed99's Avatar
E63s AMG
OP's ideal wheel spec should be fine as long as you don't run 245/ 275 width or bigger.
Anymore pics would love to see more.
Old 05-28-2017, 02:38 AM
  #35
Hsg08's Avatar
It's not as sick as your car bro @Ed99. I think your w212 has a perfect stance in my opinion 👌👍
Old 05-29-2017, 01:11 AM
  #36
Ed99's Avatar
E63s AMG
Looking good my friend. Love your front chin spoiler.
Old 05-15-2019, 12:51 PM
  #37
CryptoCoupe's Avatar
e350
Originally Posted by threeMBs
Well, actually I'm running now 9.5" at all four corners(e550w4) with 255/35-19 tires. I'm running et42 upfront and wheel/tire sticks out by 3mm (et45 would be flush but would rub on the inner strut) when measured but is not really visible and appears flush; and et35 rear and wheel/tire are flush (due to a slight stretch of 255 tire on 9.5" wheel). Since one should run a correct tire size (which 235/35-19 is not for W212 and especially not for 9.5" wide wheels since it would be narrower than the wheel) and not the one that "fits", any lower front offset than et42 for 9.5" which corresponds to et36 for 9" will result in visible tire/wheel combo being passed the fender line.
threeMB's this is my first post and excited to be on the forum! I have a 14 e350 coupe and the oem offset is et48. I'm looking to buy 19inch 9.5's all around and the offsets are +25 front and +31 rear. the rims are 114.3 so i will have to buy adapters...The smallest I've seen is 15mm. Will these wheels fit in any way or will they rub on the fender? Seems like they will stick out a little.
Old 06-24-2019, 03:26 PM
  #38
Kai Takase's Avatar
2014 E350
Nice!
Is there any issues on rubbing and do they run well especially on the front tires? I’m thinking of getting 19x10.5 too.
wmoor004 (07-01-2019)
Old 07-01-2019, 09:59 PM
  #39
wmoor004's Avatar
11 E350 4M
I am considering running this setup on my11 E350 Sport 4m.
Old 07-02-2019, 11:08 AM
  #40
Germanlove4ever's Avatar
E350 4matic
Hi everyone,
Read through the thread and appreciate all of the helpful advice I have a '14 350 4matic with stock suspension and I have a opportunity for a deal today on 4-19x9.5 with 35mm offset it appears to me that this will stick out about a inch past the stock setup(17x 8.5) if the calculations are correct? My two questions are should i definitely use 255 35 19 all around and has anyone experience rubbing with this setup?
Old 07-02-2019, 11:09 AM
  #41
E350 4matic
Any immediate nreplys are much appreciated!!! Thanks in advance!
Old 07-02-2019, 11:45 AM
  #42
Ed99's Avatar
E63s AMG
Originally Posted by Germanlove4ever
Hi everyone,
If you are planning to lower your car I would go 255/30 front and 275/30 in the rear.
Germanlove4ever (04-29-2020)
Old 07-02-2019, 12:02 PM
  #43
E350 4matic
actually i wasn't planning on lowering it thats why i was going to stick with the 35's
Old 04-28-2020, 07:03 PM
  #44
DaddyOhbluetec's Avatar
2011 e350 bluetec
I'm thinking of putting on this set up. Will these fit my 2011 e350 bluetec sport pkg? Can anyone please help with your opinions. Much appreciated.
19x9 et25
10.5x20 et57
Old 04-29-2020, 05:50 PM
  #45
Antigini's Avatar
E63
www.willtheyfit.com
This is your best friend when figuring wheel offsets and tire sizing. Plug in your current wheel specs, followed by what you're thinking for the new set and it'll give you every measurement you need. Break out the tape measure and see if it works.
pierrejoliat (04-23-2021)
Old 04-29-2020, 07:13 PM
  #46
nota_amg's Avatar
2013 SL550 BiTurbo
These wheel faces would already be out past the fenders, and you want to add 15mm adaptors?!? NO! (new offsets would be +10 in the front and +16 in the rear ...no way that will work, ever). Buy the correct wheels with the correct offset and bolt pattern.
just wanted to add, "Spacers are bad, M'kay?!?"
Old 04-29-2020, 07:26 PM
  #47
E350 4matic
Definitely a great go to website! I have a '14 e350 4matic with stock 245/45/17's and bought 19x8.5 et38 for the fronts and 19X 9.5 ET40 for the rears can i get recommendations for rear tire size? thought about 265/35/19 or 275/30/19? Thanks!
Last edited by Germanlove4ever; 04-29-2020 at 07:31 PM. Reason: needed to add more.
Old 04-29-2020, 07:37 PM
  #48
nota_amg's Avatar
2013 SL550 BiTurbo
are you lowered?
if so, 255's or 265's
if not, you can go with 275's or 285's in the rear
ultimately, overall tire size dictates usability, as 2 brands of the same exact size will have different outer dimensions
Old 04-29-2020, 07:52 PM
  #49
E350 4matic
Originally Posted by nota_amg
are you lowered?
Not lowered so probably going to go with 275's as long as the don't stick out much but fill the arches up.
Old 04-29-2020, 08:57 PM
  #50
alamry's Avatar
2014, E350 ,4matic, luxury package, AMG kit
The following 3 users liked this post by alamry:
Ed99 (05-12-2020), pierrejoliat (04-23-2021), Siegmann (08-09-2021)
Quick Reply: 19x9.5 38et and 19x10.5 32et Will this Fit???
