Rear License Plate Frame Bolt Size?
Dealer only left two bolts to secure the license plate, and they are not the same size as my CLK.
Anyone know what the bolt size is supposed to be? |
I want to say it's an M6. I took mine into lowes and bought 4 stainless steel hex head bolts. Might be easiest to take yours off and match it up inside the store.
Originally Posted by LasVegasMike
(Post 5991191)
It is an M6. However be careful with the length as it can be either too long or too short. For just a plate a 12mm length would suffice but if you add a plate frame you will probably need 16mm long ones and you might need to put a washer underneath to make sure it's not too long.
Originally Posted by GregTR
(Post 5992215)
(Post 5992215)
16mm is perfect for the OEM mounting plate + license plate (and I also have an AMG frame). |
