Sponsored by: CARiD
Drive Shaft Bearing Whine
Old Oct 10, 2014 | 09:13 PM
pascalg01's Avatar
2010 E350
Has anyone had to replace the drive shaft center support bearing? As best as I can tell, mine is whining. No change in noise level from any stress such as acceleration or cornering, but significant whining noise increasing in pitch from 20 mph on up. Noise became noticeable after a sustained one hour 120+mph romp in the middle of nowhere. 2010 E350 with 50k miles. Noise was present before and after recent tire replacement.
Old Oct 11, 2014 | 12:16 AM
pamiboy's Avatar
E 350
Are you still under some sort of warranty?
Old Oct 12, 2014 | 01:26 AM
pascalg01's Avatar
2010 E350
No
Old Oct 12, 2014 | 09:35 AM
Arrie's Avatar
Originally Posted by pascalg01
No
Have it replaced before it locks up and destroys the drive shaft.
Old Oct 13, 2014 | 11:08 PM
mleskovar's Avatar
'17 Jaguar XF
... As best as I can tell....
Have you put it up on a rack and wiggled stuff yet? Transmission output shaft bearing? Differential howl (fluid?)?
Old Oct 16, 2014 | 01:01 AM
pascalg01's Avatar
2010 E350
Turns out it's the differential pinion bearing. Requires a disassembly of the diff and replacement of all bearings and obviously seals
Old Oct 27, 2014 | 09:23 AM
pascalg01's Avatar
2010 E350
The pinion shaft seal in the differential was poorly sealed during a replacement (I couldn't say when, I just bought the car 2k mi ago). This led to a failure of the pinion shaft gear and the associated larger gear in the differential, not due to a lack of fluid (it was topped up and clean) but to excessive play which caused scoring of the gears. Thanks to RamJet in san Fernando, CA for sourcing the parts and performing an outstanding repair job that saved me over $2300 in dealer costs. It helped to find out where the dealer had this type of work done ;-)
Old Oct 28, 2014 | 06:20 AM
BenzV12's Avatar
W212 FL
Great news, I appreciate your feedback as well
Happy motoring
