Sponsored by: CARiD
NOx sensor
Old Feb 3, 2015 | 02:22 AM
taeandji's Avatar
NOx sensor
I have 2011 E350 Bluetec w/35,xxx miles and 2011 GL350 bluetec w/54,xxx miles and both of them now have CEL on...
I relocated to oversea and have local MB dealer to check e350 out and they told me NOx sensor seemed to be bad... and asking about $950 for parts and another $100 for labor.
both cars have extended warranty but I guess it is only good if they are still in state.... which is very sucks. I still have to take GL to find out the issue though.
as I mentioned above, could this issue be affected by diesel we are getting here which could be different than state side?
Is it common that NOx sensor to go out for diesel cars?
How hard is to get it replaced?
Have you had any luck or found a way to get bad parts replaced under warranty from state side MB dealer when you are relocated to US military stationed in oversea?
Old Feb 3, 2015 | 09:16 AM
CarolinaBluetec's Avatar
2008 E320 Bluetec (until 11/14), 2001 SLK 320, 2004 Volvo V70, 1972 MGB, 2013 E350
I would contact MB USA directly on the warranty issue. I have found them willing to go a long way for customer satisfaction. Since you are active duty military, I suspect they will try to help you out.
Old Feb 4, 2015 | 12:15 AM
taeandji's Avatar
Thanks for your response... I guess I will try again...
