Serpentine Belt Change on E350, 2010
Just changed out my E's belt, simple as pie. Just don't drop anything down into the engine compartment as in order to get it back you need to remove the plastic panels that cover the lower engine compartment, a real pain. There are only two pulleys where the belt's ribs don't fit into any ribs. Just put a piece of colored tape (any kind) on those two pulleys so you'll know the belts ribs fit into all the other pulleys grooves, makes the job a snap.
Doc
Doc
It's really easy, I just installed a new Gatorback belt. You can also take a phone pic beforehand to have handy for the re-installation. Good time to also check fluid levels.
