Where does de side airbag exit?
2 Attachment(s)
Never given these any thought before, but I have a dashcam installed
and running the wires through the side of the roof, under the "seals". (see pictures) But now I wonder if this does not obstruct the airbags? There's a lot of info/pics to be found on the net, but non show the exact "exit point" of the bags. :nix: |
Originally Posted by Egonvdv
(Post 6952401)
and running the wires through the side of the roof, under the "seals". (see pictures) But now I wonder if this does not obstruct the airbags? There's a lot of info/pics to be found on the net, but non show the exact "exit point" of the bags. :nix: are those wires for power or rear window camera? if for power i suggest running them down to glove box power outlet. if for rear window you should be fine , as its not gonna have any affect on airbags. |
thanks. it's indeed the cable for the rear camera (camera is hardwired in the engine bay).
so you don't think this cable will obstruct the airbag should it deploy? |
most likely not , but i would run it under roof liner panel and under pillars instead of sticking in under rubber sealing... that way you will see where airbag are and can eliminate safety issues, yes it takes a bit more time but it safer and hides wires better
one last question. on the top side I don't see this airbag plastic cover. does that mean I do not have side airbags? I only see this cover in the front (first pic) and in the back of the car behind the rear door.
(Post 6954138)
