15mm front and 20mm rear spacers
2010 e550 p2
Just wanted to share my excitement about installing spacers this past weekend , i had 15 mm in the rear for 3 weeks , and themln ordered 20mm to replace my 15mm in the back , and put 15mm in tne front. Happy with the results. Idk why i never did this sooner , first time using spacers also ,was worried , but turned out good. Handling is different , i like it.
BTW wasn't sure on how aggressive i wanted , but i this this is perfect. Just some thoughts.... thank you
Hah thats funny. I just installed 15mm spacers all around this afternoon. Made a big difference, especially up front. Good job man, looks really good. I thought you were on 20s.
Yeah i do, i have 19x8.5 up front and 19x9.5 in the rear. So with the 15mm spacers now my setup is 19x9 and 19x10. I wanted the wheels to stick out a little more and now its perfect. And you are right, the handling has changed a bit, i didnt think spacers would affect the handling but it has.
Airmousam (03-11-2017)
2010 e550 p2
yea i know , i was thinking about rear ones maybe a 40 or 45 , but i doubt there is a good selection for them , so i might just lower the rear end a bit moreso it wouldnt be so noticeable gap there , or just use differernt tire height
Im using the flat ones. Had her up to 110 mph the other night on a wide open strech of highway with no one around, and i did not experience any abnomalities. I also swapped out the lug bolts for longer ones. If anyone is thinking about spacers dont forget to get longer lug bolts as well.
Airmousam (03-12-2017)
Received 1,616 Likes
2014 E550-sold 😩
Both of your cars look great. Nicely done!
thank you for the pictures, your setup now looks exceptionally cool
do you feel the front is now flush or is it poking out a bit beyond the fenders, hence will 19x9et32 wheels sitting on 245/35 tires and lowered on Vogtland springs rub some on my 2014 e350 4matic.
The passenger side tire was rubbing ever so slightly when i went over speed bumps above 10 mph. And also during sharp dips in the on the highway at speed. However, i did have 235/40 tires which are larger than 245/35 so i think you wont rub at all. My front offsets were et32 as well.
I also tried putting spacers on the rears and again the right side was rubbing but pretty badly so i took them off. Its weird why only the ride side rubs and not the left.
alamry (05-04-2017)
I run the same 15/20mm setup on my split 6 AMG 18's in the winter. It really is incredible how much it transforms the car! I still wish I'd been able to find a white e550 with the build specs I desired. Yours looks great!
