Factory warranty about to expire on my 2014 E550 sedan; what should I get checked?
1 Post
2008 GL550 Polar White, 2014 E550 4matic Designo Diamond White Metallic
Hello, everyone. As the title states, my warranty is about to expire and I'd like to know what I should get checked out (engine, trans, seats, moldings, trim, etc.) I haven't had a single issue with my E550, but will appreciate any feedback. Thanks in advance!!
2015 Triumph Thunderbird LT 2008 Dodge Ram Bighorn 2011 Mercedes Benz E550 Sedan
I'd have them check the suspension...I just replaced my rear bags...1,700 bucks. They were leaking.
Motor and trans mounts, and if you have any concerns about future issues, the warranty extensions are reasonable if purchased through one of the guys mentioned in the extended warranty thread.
2014 E350 4M Diamond Silver
+1 ^
Try Jeff Jackson, KY he quoted me, way less than anyone can ever quote, so far
5028964411 #1246
JJackson@TafelMotors.com
5028964411 #1246
Jeff is the man, I try and stay out of recommending as I know there are a handful, but he was by far the best price of all the people. Whoops, so much for not recommending
raja777m (06-22-2017)
Interesting. How many miles are on your car?
Did they notice the leak or did you, or did you tell them to do a random check?
W212 E-class, W211 E-class, F10 5-Series
My car has 32000 miles. I'm just lucky to discover the oil leak when I tried to retrieve the nut which I dropped into the front of the engine. I opened the plastic front cover and the sheet metal which cover the power steering motor then I saw the little oil at the bottom. You couldn't see the leak if just looking at the engine.
If you have the burl wood, check to see if the wood trim is faded by comparing the portion inside the door hinge side against the rest. This was a common issue prior to 2011 but I have heard of later models with the same issue.
How is the battery holding up? At $300 a pop, it's worth asking them to check if you've had any issues (real or not).
Anyway, at least make them aware of it, for future references
I see it. Doesn't look bad though but could get worse in time. What has the dealer said? On earlier models, the customer had to complain for them to do anything. I had an SA tell me once that they were not permitted to point it out to a customer even if they noticed it.
raja777m (06-23-2017)
Also, this is not in their first preference, since, it is not a safety issue
They've covered it for past models even though it is not a safety issue. And how do they measure whether is is bad enough or not - is there some sort of faded wood scale? If you the customer are unhappy than it is an issue they should address. If this SA doesn't think it is faded, then try another SA or dealership as it doesn't cost you anything to try.
Received 1,466 Likes
Anyway, I have to take the vehilce again sometime next week, as, there was a recall/recommendation by MB to the previous owner (back in 2016), about some harness for radar senors or other sensors in the back bumper needs replacement.
Which will be re-assessed and will be replaced or whatever, so, I'll mention about.
1. Wood trim,
2. Aux battery, to do a load test, as ECO takes time to activate,
3. Bluetooth streaming still skips, while playing on iOS.
4. Rear parking sensors doesn't recognize walls while parking.
BTW, with the new firmware upgrade, one important feature has been fd up.
While driving forward, the 360 Camera used to display upto 17mph or 19mph, now it is limited to 10mph.
The problem is, while pulling into a parking and driving at 15mph, I cannot activate the camera, I have to drop it to 10mph or less, in order to calculate the curb, etc. that is fing ridiculous, In my experience.
to the OP, make sure there is no rust under the vehicle..!
My vehicle is initially from NYC and the SA said, there is some rust(the vehicle definitely seen some salt), but that is not something alarming, and they can't do anything about that.
I don't know the amount/size/level of rust personally, so, anyone, what is your take/experience/suggestion on this matter? Doesn't MB care/prevent further rust?
I think they covered it under the bumper to bumper warranty. I think if the dealer doesn't want to cover it, you have to call MB to make them cover it. It's considered cosmetic which the bumper to bumper warranty covers, but the extended warranty doesn't so it's your only shot to get it done.
I have an issue with the leather seat in my car and Mercedes is kind of being hesitant on covering it under warranty
I have a question. What exactly is considered Bumper to Bumper, and what exactly is considered cosmetic. Are these terms subjective? I know that a bumper to bumper warranty is supposed to cover pretty much everything in the car to the owner satisfaction, but it's owner satisfaction subjective in the eyes of Mercedes-Benz?
