Key Fob Battery replace message
Hello guys!
I recently replace 2 CR2025 on my 2013 E550 4Matic which I bought from Target. Do I need to reset the message after replaced the battery, It's irritating me that I have to press OK every time the "Replace Key Fob Battery" message appeared. |
I am not aware of having to reset anything once the battery is replaced. You may have a problem not associated with the key or battery. Try using your other key with a fresh battery and leave the other key in the house.
The message has always gone away for me after the next startup. You may want to check the voltage on the 'new' battery that you put it. Just to be sure it's not stale.
Originally Posted by KEY08
(Post 7374327)
Originally Posted by thefisch
(Post 7374440)
Originally Posted by Leonardick
(Post 7374634)
As long as it's a CR2025 it should have the same volt out put?
Get a multimeter and check. New they are anywhere from 3.25-3.31 volts. I get the message once they hit 3.06 or below. You can also buy them on Amazon or Ebay in 5 or 10 packs or more.
Originally Posted by cetialpha5
(Post 7374778)
If problem still exists after replacing batteries id suggest to check the Aux battery condition.
I had that problem happen to me. I replaced my key fob battery but the message didn't go away for like a week. I took the battery out of the key fob and put it back in (same battery) and the message stopped appearing. I dunno if this solution will work for you, but it worked for me.
Originally Posted by Peachy
(Post 7376502)
for me, with the new battery in place, there is no error message anymore.
(Post 7374281)
Hello guys!
Yeah, Fisch called it again and his head keeps getting bigger. |
(Post 7382329)
(Post 7382578)
Even a blind squirrel finds a nut once in a while...
(Post 7374281)
Hello guys!
(Post 7374281)
Hello guys!
