I have question for W212 E350 Brake Upgrade
Hi.
Before I start... I am not English speaker.. sorry about the word and grammar Currently, I'm driving 12 E350 bluetec model. My car have one piston brake caliper now. For now, I will be change my brake pad and rotor, so it is very good time to upgrade front caliper. I want to upgrade 1 to 4 piston brake which is transfer e350 to e550 brake. I know when I changed 1 to 4 piston, I have to change brake pad and rotor too. My specific question is BRAKE CALIPERS. Look at the photo I think.....(not sure, if wrong please tell me) there are the same part number4 (i'm not sure what is the name... probably caliper guide?) The only difference is the brake caliper it self which part number is 3. So, If I want to upgrade my brake caliper then Can I buy only number 3 part? or what do i need to do Also, If somebody know the w212 e550 front calipers please let me know the part number as well Thankshttps://cimg3.ibsrv.net/gimg/www.mbw...633f59345a.png |
Have you cross referenced the Brake master Cylinder from the 350 to 550 setup? |
Originally Posted by KEY08
(Post 7424565)
Bigger brakes, more pistons. Worth checking. |
If it helps. On my 13 w212 I'm doing the same thing. I'm taking Brembo brake calipers from a 14 e550 and putting them on my 13 e350
Already checked with the dealer. They will bolt right on. I'll be doing a thread once I'm done with this. |
Originally Posted by Heisenberg5070
(Post 7424571)
Already checked with the dealer. They will bolt right on. I'll be doing a thread once I'm done with this. Thanks for respond. So, did you just changed calipers(including rotors and pad)? still using your master cylinder? |
Originally Posted by yeom949
Thanks for respond.
(Post 7424585)
You need to change rotors and pads ofcourse. I have part numbers for everything. Dealer didn't say anything about changing the master cylinder. So you should be fine.
May i asking about the part number or anything you have any information? |
It appears the master cylinder is the same for both. |
Thanks and it is good news for me.
May i asking about the part number or anything you have any information? Rotors: A000421201207 $285 Brake pads: A0074209920 $145 Calipers part numbers A 218 421 2098 left -left A 218 421 2198 right-right |
If you want to get Brembo front pads they are much cheaper. Part number is P50098N
Different issue and couple of questions:
I have Non-OEM brake pads and rotors as per mentioned by dealer (attached image). According to them, that is the cause of some metal clanking noise when going over speed bumps (after they replaced sway bar links). Now, the brake are fine as of now, but if I have to upgrade to them, I prefer to go over this route. Dealer quoted 660$ for new MB brake pads, MB rotors. But I was thinking of buying off calipers from E550 (ebay or here from forum members) and get NEW brake pads (MB or Brembo - whichever is cheaper) and rotors. 1. I believe a sticky with compatible part numbers for front and rear: brake pads, rotors and calipers would be great. Those car gurus - please help with that :) 2. Do we need to worry about rear upgrade also? 3. Will 17" OEM wheels cause any trouble for 4-piston brembo brake set from E550 on my E350? Thanks. Apologize for the enlarged image size. https://cimg7.ibsrv.net/gimg/www.mbw...19117b1754.png |
I believe you need 18” rims to clear the much larger rotors and calipers. The E550’s got 360mm rotors vs 340mm plus larger calipers. Get aftermarket rotors as the OE rotors are famous for warping. They are also much cheaper than stock. Win - win. |
Originally Posted by raja777m
(Post 7427706)
Originally Posted by aris1964
(Post 7649584)
I have the same concern, to upgrade my breaks. Did you verify if the new 4pistons callipers fit to in 17" wheels?
