Creaking in front suspension
I posted this in the CLS forum but it is kind of dead there so I thought I'd post it here too since the CLS is based on the E-sedan. My wife has a 2013 CLS550 we bought CPO. We purchased the extended warranty when we bought it and we have a couple years left on that but we have had it in now 4 times for a creaking noise in the front suspension when going over speed bumps, dips etc. They replaced both front struts and the front sway bar and now they replaced both lower control arms. Dealer says creak is gone but there is still a slight squeak they are addressing.
Has anyone else experienced this and had it fixed? If so what was the cause? The car has approx. 60k miles on it currently. We love the car but this is kind of annoying... glad we purchased the extended warranty though. |
My E550 has been a little creaky lately. Interested to see what the solution is but I haven't looked into it.
same as mine....Creakyyyyy
But mine is the rear... I am also thinking replace out all the control arms, struts and sway bar. Its going to be very costy for me. |
I experienced a similar creaking sound over bumps in my C320 at 85,000 miles. An independent repair shop diagnosed and replaced both lower control arms (front) at 95,000 miles. Apparently the bushings dry/wear out, and MB recommends replacing these at about 90,000 mi as normal maintenance (or so the shop told me). The creak has since disappeared in front, but I now have it in the rear suspension. Probably bushings there, too.
In my case, there was no need to replace struts or sway bars, etc. Although I imagine that anything with a bushing will get old with time. HTH. |
I had some creaking like this in my Range Rover at the end of last winter so what I did is went underneath and sprayed molybdenum Grease in all of the bushings I could get to. problem solved.
Might help |
are your front brake pads and rotors aftermarket? cause mine are..!
They replaced the broken sway bar bracket in the rear under ELW. https://cimg3.ibsrv.net/gimg/www.mbw...ebaa70dc88.png |
Originally Posted by Ariesfamous
(Post 7433179)
Might help |
Originally Posted by bachree
(Post 7433191)
I'll try this! Is this similar to what you applied? https://www.amazon.com/CRC-03084-Net...ybdenum+grease
I have a slight clicking/creaking sound at very low speeds on the front side of my 2010 e350. I remember it was driving me nuts when I pulled into the Starbucks window and could hear it creaking before , lol. Hope it works! |
I’ll watch this thread, too. My 2015 E400 is in for a creaking noise in the left front suspension. Noise has been there since new, now have 25K miles. When the underside of the car is wet (rainy, etc.) - no noise. Once it dries - noise returns. This is the 4th trip to dealer for same noise. They could never replicate it. This time, I took service manager for a trip around the block. Showed up the noise right away. It it will be interesting to see what cause and remedy they find. |
Hello, is there currently any solution. I have the same issue in my 2014 E350 4matic Sport. When Running over Bumps at any speed under 55 mph. Ball joints and bushings may need lubricants and also needs to be checked for normal wear and tear on ball joints and bushings. Again the W212 chassis is still quite new for any real common problems in this category. I think it is definitely coming from joints and bushings. Also brake pads could have wear and rotors too. Please respond soon. |
My noise and creaking was the struts. Replaced both and the creaking went away.
Glad that struts helped your car. No help for mine. My noise has been at the left front, since the car was nearly new. They replaced the left front strut. No change.
Lately, the noise in my car has become temperature sensitive. It is quiet in the summer and fall, but now that temps are dropping into the 20's, the noise is coming back. I'll wait until the temp is sure to be cold enough, then back it goes. It spent 5 weeks at dealer last spring, but the weather got warm while they had it and noise went away. This time, I want them to get to troubleshoot it, not have it hide. |
I wish you well! Best of luck with that. My creak, { I think} has gone away but I haven't been in a closed parking lot yet to hear it. To me mine sounded like the body was flexing. I have my fingers crossed it wont creak anymore. Its the clunking that almost put me in a tail spin.
I have had to make the major adjustment from my old car (LS430) to the E400 with steel springs/sport suspension. This is a completely different sort of car. The Lexus was nearly silent until you punched it, and then you heard the V8 trying to suck the hood into the air intake. Absolutely NO squeaks or rattles all the way to the 157K miles at trade-in. The E400, with its lower and stiffer suspension, is just a rattletrap by comparison. The Lexus handled better (believe it or not), was more composed, had a far better sound system. . . but it was old and slower. The E400 flies, in comparison. IIRC, the LS430 was said to do the 0-60 sprint in 6.3 seconds. Quite good for a 2001 luxocruiser. The E400, OTOH, did 0-60 in 5.0 seconds, per the Car and Driver instrumented test in 2015.
I have many little rattles in the car, but it is just too much fun to drive to let those get to me. Big creaking noises, though. . . |
Okay
So I lubricated all the joints and the struts with a spray type lubricant that is corrosion resistant and repels water and it also helps maintain the life of rubber materials. all the joints I sprayed and struts. I do not have anymore squeaks when I roll over a bump. I used Motul C4 |
That could be an issue in areas that use things for snow, I’m in an area it never rains. Sqeaks are different than creaks. |
Originally Posted by SteveE400
(Post 7641391)
I just replaced both and it’s quiet as a mouse. I still have the slightest of creaking but it sound to me like a bad rivet point on the drivers side. It doesn’t bother me because I now don’t have the clunking of the bad struts and my radio covers the noise. Maybe they put a defective strut on your car the second go round. I know with my Jag, it took 3 sets of front struts to get a quiet pair. |
Originally Posted by SDRider
(Post 7432553)
Has anyone else experienced this and had it fixed? If so what was the cause? The car has approx. 60k miles on it currently. We love the car but this is kind of annoying... glad we purchased the extended warranty though. Are you sure the squeak is coming from the suspension? I had a squeak that sounded like a chirping bird every time I went over a bump or pothole. Took it to the dealer get looked at, and they replaced a few parts including the front strut, sway bar, bushings, and nothing helped. I'm happy for those parts though. They claimed it was fixed, but it clearly was not. There was a park near me that had a brick crosswalk. It squeaked EVERY time I drove over it. I took their master tech on a ride with me over to the park and showed him. He said he definitely heard it. The issue was pinpointed to the outside brake pad on the driver's side being loose and shifting around over bumps. They were nice and took care of the cost since this was a wear and tear issue, but I took it home like that. I bought some cheap anti brake squeal and put it on the brake pad guide pins. Headed straight away to the park, but I could already tell the issue was fixed before I even got there. After that point, I replaced all the pads and rotors, as well as inspected the caliper guide pins and lubricated them. It's been smooth as silk since then! |
Mine is a definite creak in the body. Take offs and going really slow in a parking lot in circles is the only time you hear mine. I’m just resigned to the fact, it is what it is and will have to tune it out. Also, just turning on the radio at any volume covers it up. I just like to sometimes drive in pure silence. Guess I’ll just have to do that I’m my S Coupe, now that’s a tomb |
Originally Posted by 2014CL600
(Post 7652519)
Mine is a definite creak in the body. Take offs and going really slow in a parking lot in circles is the only time you hear mine. I’m just resigned to the fact, it is what it is and will have to tune it out. Also, just turning on the radio at any volume covers it up. I just like to sometimes drive in pure silence. Guess I’ll just have to do that I’m my S Coupe, now that’s a tomb Last spring, when I took it to the dealer, I was able to show their senior tech how to cause the noise. I just crept over a speed bump about a block from the dealership. They still couldn't fine the cause. I guess it could also be a plastic part scraping against the suspension -- maybe an underbody cover or inner fender panel. It could be rubbing, rather than creaking. You can almost feel it. I doubt that it will ever "go away." I'm taking the car in for new tires and alignment in a couple of weeks. If it is cold at that time, I will let the current servicing dealer look into it. I "fired" the selling dealer's service department when the kept the car for over 5 weeks and accomplished nothing. |
I think it is a structural issue. Sounds like a weld or body flex to me at least on my car |
Question
(Post 7433603)
Originally Posted by Edgardo Aguilar
(Post 8401392)
Did you ever find out the issue? My 2017 e300 has the same problem.
Front suspension noise only from driver side over speed bumps since very 1st mile. My money is on a stabilizer link or stabilizer bushing... more so than a ball joint. |
yeah, antisway mounts are a common cause of suspension squeakks.
