Check Front Left and Right Parking Lamp warning help
I've done some searching online but now I'm posting since I can't find a fix for this. I have a 2012 E350 and I'm getting the warning to "Check Front Left Parking Lamp" (and my right lamp). I purchased two OEM Mercedes bulbs, put them in but they do not light up and I still get the warning. Yesterday, I took a multi meter and did a continuity test on both pins on both sockets which worked great so they seem to be connected. Anyone have any advice on what else I should look at or test?
Could it possibly be that you have to polarities reversed? I know that's was an issue when I converted mine to LED on my last 3 Mercedes.
Try power cycling your vehicle to reset the SAM.
Originally Posted by huewish
(Post 7468075)
Originally Posted by AZN Optics
(Post 7468128)
2 Attachment(s)
Reluctant to disconnect battery, check wiring to front SAM underside – corrosion, etc.
Originally Posted by hooker350
(Post 7470025)
How would I do that? Also wouldn't this cause a ton of errors to pop up? Video's I've seen about swapping batteries in this car mention a complete power disconnect causes all sorts of issues |
