AC only works when cold - code P261115
Hi all,
Recently acquired a W212 E63 and the A/C is only working while the engine/car is cold. Here is the scenario: - when I first start car in the morning, the A/C will blow cold for about 5-20 minutes of driving - duration is shorter if the outside ambient is higher, say if it was 28c, it might only work for 5 minutes, but if it was 20c it might work for 15 minutes - after a certain duration, the AC light will turn off by itself, and when I try it turn it back on, the AC light will immediately blink 3 times showing an error. - if I shut off and restart the car immediately, I can turn on the A/C and the light will stay on for about 10 seconds, then it will trip off again, if I try to press it again, it will blink 3 times. - after I park it for a few hours and the car has cooled down, it will return to the cold start scenario where the A/C will work for a duration of time. The first try was to check the refrigerant levels, mechanic evacuated system and there was the factory specified amount of refrigerant inside system and a leak test was done and everything was fine. However the error remains, Pulled the code, and the reader shows: "P261115 - The regulating valve for climate control has a malfunction, there is a short circuit to positive or an open circuit (current and stored)" My mechanic suspects that this regulating valve was shorting out when the temperature was hot. The official way is to replace the compressor as the "regulating valve" is an integral part of the Denso 6SEU16C compressor. However, I found the solenoid valve itself for the 6SEU16C compressor on eBay for about 40$ we evacuated the system again and replaced the solenoid valve on the A/C compressor and recharged the system. It did not solve the problem and the symptoms are exactly the same as before. Ac blows cold for a while, and then trips off. Since I have replaced the valve and made no difference, I am wondering if my mechanic has proposed the wrong solution, is the "regulating valve for climate control" really the solenoid valve on the compressor? Or is there other regulating valve I'm not aware of and we are just barking up the wrong tree and replaced the wrong valve? Thanks in advance. |
The Heater Core Valve on the W211 was a big problem for many, including myself. It caused the AC to blow warm air after operating for a short period. It would work again after cool down as you have indicated.
It is a regulating valve and perhaps this is the valve giving you the trouble code. see more: https://mbworld.org/forums/e-class-w...rol-valve.html |
Thanks for your help. I owned a W211 before as well and I'm familiar with the duo valve.
However, when I checked the parts catalog in the W212 I'm not able to find a similar duo valve anymore. I wonder if they have used a different control for the W212 HVAC system that got rid of this control valve. |
That is certainly possible, but I don't know how the system would operate without a regulating valve controlling the flow of coolant. This descriptor "there is a short circuit to positive or an open circuit" in the fault code was my issue. That Heater Core Valve is controlled by the front S.A.M. and I had a bad S.A.M. that was not signaling the Heater Core Valve to open or close properly. The S.A.M. needed to be replaced for $1,000. I hope you can get this sorted.
Key08, thanks for your help and I'm afraid you are correct that it might be the SAM module, even though for W212 its no longer controlling the duo valve. The W212 now uses an electric heater circulation pump to control the amount of heat. The SAM controls both the heater pump and the AC compressor regulating valve.
Me and my mechanic spent some more time troubleshooting yesterday and hooked up the scan tool to monitor the front SAM module signals. When the car first turns on and AC is turned on, approx. 0.8A is applied to the AC regulating valve and the AC works fine. And the status of the compressor is set to "ON" on the SAM module. As long as I keep the temperature in "Low" and the Ac compressor cooling has constantly shown as "ON", the AC seems to work fine. However, once I set the temperature to a higher temp, say 22c, the compressor will cycle off when cooling isn't required. And when I set the temp to a lower setpoint, the SAM module tries to turns the compressor status to "ON", however the amp draw remains to be "0 Amps" in the display data. Then instantly it will switch off again, and on again. It tries to turn "ON" but since there is no amp draw, it turns off again. It tries this for about 10 seconds, and its unsuccessful in turning on the AC compressor, so it trips off the AC and the AC will blink 3 times as I try to turn it back on. It will now show the code "Regulating valve for AC is open or short circuit" I then turned off the car, and instantly turn it back on, and tried to turn on AC again, it attempts to turn "ON" the AC compressor without success and trips off again. The next try, I waited only around 3 minutes to restart the car, everything was still up to temp, and this time the Ac compressor kicked on again, as long as i kept it in "low" setting, the compressor stays on. This confirms that the Ac regulating valve was NOT the culprit as being too hot and short circuited. Everything was still very hot in the engine bay, and as long as i kept it in "Low" temp setting, the AC continued operating without issues. We concluded it was something to do electrical controls. The AC regulating valve is directly controlled by the front SAM. So I thought maybe I would try my luck with the relays on the SAM. I removed and replaced a couple of grey relays in the SAM module and the AC suddenly worked as intended! I was very happy but it was short lived, only lasted for about 20minutes before the AC compressor wouldn't turn on again. I then went online to Google if others have similar issue with the W212. I found that the guys with SLK seem to have a similar issue and its apparently very common for them. See thread below. I'm now asking the dealer how much a SAM module replacement is, and may try the DIY repair below if the replacement cost is too high. http://www.slkworld.com/slk-r171-cla...d-bad-sam.html |
Keith nailed another one.
Good troubleshooting btw |
Ha, Fisch! Not nailed yet, but these SAM’s can cause all kinds of grief. Your write up will definitely help others looking for a solution and thank you for sharing the process. You are on the right track for sure. |
hi mate
l have same problem do you reslove this problem
So this weekend I found some time to take out the SAM module and attempt the Slk forum repair. Unfortunately our SAM module is a completely different design and all the capacitors are SMD components now and I can't see any capacitor that burned out or broken solder anywhere. Put the SAM module back in the car and the problem remains. Looks like I'll have to bite the bullet and buy a replacement SAM. Does anyone know if a used SAM module can be coded using STAR to work? Or do I have to purchase a brand new one. Dealer wants $1200CAD and will not code any module that is not purchased from them. Even if it's an OEM part purchased from online. They won't touch it.https://cimg7.ibsrv.net/gimg/www.mbw...df2e55539f.jpg |
Originally Posted by Prostrho
(Post 7486748)
Even if it's an OEM part purchased from online. They won't touch it. Husker is online MB dealer with great pricing. One time I had warranty issue and took it to local dealer. Per talk with part person any MB part bought from any MB dealer in USA has to be serviced by any other MB dealer. |
Originally Posted by kajtek1
(Post 7487032)
Are you talking online reseller, or online dealer?
Husker is online MB dealer with great pricing. One time I had warranty issue and took it to local dealer. Per talk with part person any MB part bought from any MB dealer in USA has to be serviced by any other MB dealer. Canada MSRP for the Front SAM = 1275$CAD. Online Husker Mercedes dealer purchase of Front SAM = 530$ USD. (~$700CAD) |
How many MB dealers you have within comfortable driving range?
Per my experience in USA, they do wary a lot in pricing depends on location. Once I witnessed a scene at San Francisco area dealer, where an owner was *****ing how the dealer charges for oil filter 50% more than his Florida hometown dealer. Another story is that I was calling local MB parts department and present myself as business owner (non-automotive). They would not honor my licence for discount, but at the end they always offer me at least 10% off. So if you have couple of dealers in your area, I would print Husker pricing and go to one of them, asking to talk to a manager. |
Hi guys i do have same problem with w212 e220
2015 reg it has no heater valve shut off at all (in 2013 they do have) not sure its has no..... maybe due ad blue...... or something..... same problem.... start car ac blinks 3 times and turns off.... changed pump, pressure sensor, valve on air con pipes......... nothing same problem.... on star c4 computer when do diagnostics i can activate magnetic clutch but a9 unit cant test... on my another car it lets to test it...... now last thing what i think is SAM or wiring..... have someone sorted this problem ? thanks |
Sorry for the late reply guys. Mine turned out to be an wiring issue. I hope you solved your issue.
(Post 7949633)
Had a few PM regarding this.
Verified the compressor would still work if 12v was applied directly to solenoid valve after the error shows up in car and AC light inside blink 3 times. My mechanic connected a direct wire connection from SAM module directly to solenoid valve of ac compressor and ac has been working fine since. |
(Post 8405963)
