Confirm wheel spacer to get
Hello... can someone please let me know if the following will work for a 2010 e350.
Front: I'll be going with the DR Series Trak Wheel Spacers in 15mm. Will the bolt below work with this spacer? https://cimg4.ibsrv.net/gimg/www.mbw...2017f70450.png Rear: ECS sites has MB listed but not E350. https://cimg5.ibsrv.net/gimg/www.mbw...20ff7f5a5d.png |
Here is the car for reference.
https://cimg5.ibsrv.net/gimg/www.mbw...84db69ef4a.jpg |
Front looks right
but in the rear i think if i remember correctly ive used 50mm bolts with 20mm spacers. 43 might not be long enough |
Originally Posted by belarus27
(Post 7481542)
Front looks right
Trak kits comes with bolts. You don't need to buy them.
Originally Posted by VdubbG
(Post 7481837)
Those bolts will not work. W212 needs 14x1.5, these are 12x1.5.
Originally Posted by threeMBs
(Post 7482080)
Ok, found the correct bolts...
https://cimg1.ibsrv.net/gimg/www.mbw...882382e9ce.png I'm assuming the DRA Trak spacers for the rears are good? as it shows on cart... https://cimg7.ibsrv.net/gimg/www.mbw...4f88e5fe68.png |
Originally Posted by 2 EURO
(Post 7482147)
(Post 7482646)
DRA spacers are fine for the rear. For front, 15mm DR 3055665 won't fit front's hub due to dust cap. Car requires 15mm DR 30556659 (so called "front" only spacer) instead.
https://cimg5.ibsrv.net/gimg/www.mbw...d8e270fc8a.png |
Yes on spacers.
Above bolts are R13, and while will be just fine, are more suitable for Audi OEM wheels rather than Mercedes OEM wheels.Try finding R14 a.k.a. Mercedes Ball Seat. R14 bolts are usually HRE bolts, not ECS (but ECS sells them too). |
