Go Back  MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W212)
Check Washer Fluid alert won't turn off after adding Mercedes approved Summer Fit >
Old 10-07-2018, 12:31 AM
Jeff Ostroff's Avatar
2014 Mercedes-Benz E-Class E350 (W212)
My Check Washer Fluid alert message came on in my multifuction display, 2014 E350.
I did it by the book, used Mercedes SummerFit, mixed it 100:1 just like the recipe says, mixed it with a bottle of Zephyr Hills water from our local store.
This is not de-ionized water, and this is not distilled water, which Mercedes tells you not to use.
I did not use any Rain-X window washer fluid, as Mercedes and several others tell you not to us either.
So I filled the washer reservoir up to the top with the official mixture I made from Mercedes own Summer Fit product, and still the Check Washer Fluid message will not go away.
What can be done, I did everything text book?
Jeff Ostroff is offline
Old 10-07-2018, 02:05 AM
cetialpha5's Avatar
Probably a bad sensor. I replaced mine on my 2011 not too long ago. It was around $10 or so. You do have to kind of get to it through the wheel well and take off a bunch of panels. But it popped off quite easily and the new one popped in. Even got the gasket for it, but the old one was fine and didn't leak. The old and new one looked identical, the probe basically looked fine, I was expecting to see it gunked up from maybe the previous owner who may have used rainx or whatever, but I guess it's just one of those electrical items which can just fail for no reason.
cetialpha5 is offline
Old 10-07-2018, 11:23 AM
Drain fluid then add some water and soap detergent into the container drive car on bumpy road so container is shaken. use sprayer on windshield then drain again and put normal fluid in. The detergent may free up sensor otherwise you need to do what the above post suggests for $10
dbldpr is offline
Old 10-07-2018, 02:30 PM
belarus27's Avatar
2010 e550 p2
When i just bought the car i had the same thing , turned out to be wire problem at the sensor
belarus27 is offline
Old 10-07-2018, 07:58 PM
A wire problem? what did you do to resolve the wire problem?
Old 10-07-2018, 08:37 PM
QUICKSHIFT's Avatar
2014 E-350 4 MATIC
Is it really that critical to use the Benz fluid? I used a high detergent washer fluid in our E320 for years and never had a problem. With the new E350 , I don't need any aggravation.
QUICKSHIFT is offline
Old 10-07-2018, 09:15 PM
cetialpha5's Avatar
Not really. The sensor measures some kind of resistance so it needs to be the right ph in order for it not to think that it's out. Usually the regular blue stuff from Walmart is fine. Pure water might be neutral enough for it to think it's out.
Old 10-07-2018, 09:31 PM
KEY08's Avatar
2014 E550 4Matic Designo Diamond White and loaded up
All I have ever used is the cheap blue bottle. This has been discussed many times.
KEY08 is offline
Old 10-08-2018, 11:32 AM
I have read other forum posts where people ran into trouble buying the super cheap stuff, so the recommendations was to buy higher quality gallons of it, or simply buy the Mercedes SummerFit and WinterFit and mix them 100:1 according to the instructions. But most car makers say to stay away from RainX Brand which is odd, there must be something in their formula that causes problems with the sensor. I'll have to look more closely at my sensor and see if there's an issue with it.
Old 10-08-2018, 11:55 AM
KEY08's Avatar
Yes, RainX has been the source of several problems. Don't ever use that stuff.
KEY08 is offline
Old 10-08-2018, 05:45 PM
belarus27's Avatar
2010 e550 p2
bad contact or connector. I can look for a record , if needed.
but looks like it was easy and only took them a few minutes to fix.
Quick Reply: Check Washer Fluid alert won't turn off after adding Mercedes approved Summer Fit
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
