20” staggered tire size for E350 4matic
2011 E350 4matic
Need help with choosing the right tire size as close as possible the same diameter for my e350 with stock suspension ..Wheel are 20x8 front and 20x10 rear..any info would be appreciated..thanks!
Welcome to the forum.
Use this online tool to compare sizes for closest possible match front to rear. You will need to base line your stock wheel/tire size to your first 20" setup for speedometer error then use that setup to chose your next tire rim combo. Some mismatch is allowed but I don't know what the actual percentage is.
Good luck,
Bob
Good luck,
Bob
