Buying an E350 gas or diesel?
So I’m looking at purchasing an E350 and I have 2 different cars available right now that I’d like some help choosing between. One is a 2010 E350 with about 42000 miles and the other is a 2011 E350 Bluetec with about 46000 miles. Both seem to be well kept and both are the exact same price.
I like the reputation of the mb diesel motors and the better fuel efficiency. But I keep reading about gaskets leaking and crazy repairs with quite low miles... I’d mostly be attracted to the diesel because I thought they were supposed to be more reliable, but online reviews make it sound like a some are just money pits.
I like the idea of the normal gas engine too, I can probably work on it easier, no turbocharger to go bad, but were the 2010 models less reliable because it was the first year for this car? Does the gas engine have the same gasket problem?
Which is going to most likely be more reliable in the end and cost less to own? Are there some things to look out for? Am I better off with a different model all together considering I’m looking for decent reliability?
what one would you buy?
I have an '11 E350 Bluetec with 55K miles, and have had the dreaded oil cooler seal leak, which I repaired myself with 16 hours of heavy wrenching. The new Viton seals are lasting a LOT longer from what I know.
There have been a couple other issues with fuel pressure sensors throwing codes, which I replaced, but otherwise the engine has been very strong and very economical. My wife drives it and we never want to sell it.
You can expect crank position sensors to fail every 50K (common on all MB - easy fix), and transmission mounts to sag and need replacing about 50K (again a common failure - easy fix), and the motor mounts to go at about 75K (common MB issue), and batteries to last no longer than 4 years.
If you change the trans fluid every 39K miles (standard interval) the trans is happy. Many will tell you to change the engine oil at 5K, not the 10K interval MB shows. Good idea, can't hurt.
I also use a cetane lubricity additive in the tank which improves mileage another 1-2 MPG and helps the injectors and such.
The failure I expect down the road is the intake tumbler valve, which can be disabled with minimal issues. Otherwise you have to replace the intakes for $1500, which I won't do.
Those are what you can expect from a diesel, as well as a few issues for gas or diesel.
Other than that, I drive it like I stole it and really like the diesel.
In the past they would keep going got 300, 400, 500, 600 thousand miles without much of engine work.
Now due to newer emission requirement and more demanding technology they require more maintenance on the way but so does SBC, Airmatic, balance shafts, radars and dozens of other parts you have not seen on older cars.
I like diesels to start with and I know how to work on them and more than that I love the immediate gas pedal response where engine will pull the car without dropping multiple gears.
Still small details aside, it cost me 7- 8 cents in fuel to drive 1 mile. Try that on premium.
Otherwise, no expensive issues. No fluid leaks, does not burn oil and is a fabulous vehicle to drive. Also have a 2015 GL550 and a 2013 SL550 Edition1. I drive the wagon a lot and would take it anywhere without any concerns!
Bought Sprinter van yesterday in high and extended version.
Powered by the same 4-banger I have in E250 BT, but for van application the engine is detuned to 161 HP.
So I was expecting underpower symptoms I remember from times when I was driving 44 HP Volkswagen.
No such thing. The 4-cylinder torque not only makes it moving in traffic (we cut from San Diego via LA agromelation in early afternoon) but van was taking most of grades without downshifting. Only on 17 miles Baker grade it downshifted 3/4 up the climb and this grade is famous for overheated vehicles fires.
Averaged 22.7 mpg keeping CC at 70 mph, but that include LA traffic.
Van has 255,000 miles on it.
Issues...
(i) rear airmatic springs, replaced with Arnott.
(ii) front airmatic assemblies, replaced with OEM
(iii) brake pads, but original disks (but they're due for a change)
(iv) ECU
(v) corrugated pipe thing that feeds air from above radiator to air filter, disintegrated with heat, need second replacement but don't think part is available.
(vi) rain sensor (reported bad but may be harness) installed new but never calibrated.
(vii) oil level, changed sensor twice, still gives error, need to investigate.
(viii) door locking switch replaced, cosmetic.
(ix) steering wheel push buttons replaced, cosmetic
(x) there was a centrifugal oil scavenging thing that was between the back of the RH bank of cylinder and the firewall, it was leaking, tricky to get to.
(xi) alternator replaced but suspect it was just a bad battery.
(xii) no light bulbs! that'll jinx things
(xiii) I do have a slow freon link, top off every 2 years.
(xiv) twice a year the transmission does a strange downshift.
(xv) I can no longer turn the AC off, but then I'm in Houston so no big loss.
(xvi) have panoramic roof so did drop headliner to tighten bolts.
(xvii) on journeys over 150 miles I get an airmatic warning, but car doesn't drop when parked, may just be weak compressor.
I'm probably missing a couple of things, I've had it way longer than expected, just love the NA V8.
Peter
