Sponsored by: CARiD
AC Compressor Top Bolt
Old Nov 25, 2018 | 02:12 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
I have some details about this in my engine mount thread, but I wanted to start a specific thread on this topic for visibility. The short version of the story is that I had to remove the AC compressor to do engine mounts and I cannot get the top bolt started. I can get it pushed in far enough so that it should grab, but it never does. Brand new bolt from dealer. Right now it's just dangling there. Had same problem with the old one too. Any tips?
Old Nov 25, 2018 | 04:28 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
#2 bolt is the problem, correct?
I have the M276 motor in my car so no direct knowledge to share. Can you get any bolt started? It would seem to me that you have an alignment problem and getting just any bolt started would allow you to pivot the other two into position. According to EPC,(attached) bolts are M8x90mm long (3.543") so make sure that what you have is long enough. Sometimes working alone gets frustrating without that anatomically missing third hand to hold a heavy part while fishing for a hole.
I'm posting a couple of reference docs....
Good luck,
Bob.
File Type: pdf
Old Nov 25, 2018 | 05:27 PM
300SE1993's Avatar
Good luck,
Bob.
Thanks for that. Yes it's #2 bolt I am having trouble with. So, the attached document said to remove #1 first, then install in reverse order. I loosened #1 and tried wiggling things around and still nothing. I am about to hook up my remote viewer camera thing and see if I can get some insight that way. The frustration factor is through the roof on this!
The car is driveable though with just the two bolts and the belt holding it in, but I don't really want to leave it that way.
Old Nov 25, 2018 | 06:27 PM
300SE1993's Avatar
MISSION SUCCESS!! I wanted to share what I did in case it may help others. So, I used a remote viewer from the top end of the hole down in (see screenshot) and I was able to see that the bolt was butting up against the back of the bracket. I got a prybar and gently pried the compressor forward after loosening bolt #1 a bit and was able to get it in, and it went in nice and smooth. Wow, now I finally feel good about this.
Oh, and the wrench I used was a Craftsman "Universal ratcheting flex wrench" BRILLIANT tool and highly recommended! https://www.sears.com/craftsman-cm-w...1&blockType=G1
Old Nov 26, 2018 | 07:52 PM
MBNUT1's Avatar
2010 E350 4Matic
Congratulations on a job completed.
Old Nov 27, 2018 | 11:25 AM
300SE1993's Avatar
Thanks! It was quite an adventure. Now, onto that intake manifold. I don't expect that to be nearly as rough!
