Need help with tire size for 19" AMG E63 wheels on my E350
I have a 2014 E350 and just bought some 19" staggered (8.5, 9.5) AMG wheels that have a 35mm offset. I know Mercedes puts 255/35R19's and 285/30R19's on the E63 but I think that these would be too big for my E350. I am thinking 245's/275's would be better but wanted to see if someone more knowledgeable than me had any opinions.....thanks!
Received 1,616 Likes
2014 E550-sold 😩
I use the 19" E63 AMG staggered wheels in the summer months. The offsets are 37 (front) and 52 (rear). This is the multispoke design shown here on my car.
Tires are 245/35-19 and 285/30-19. I have 4Matic, so it's important to keep the rolling diameter as close to zero as possible. This is a .1% difference.
Your 350 and my 550 come with the same OEM offset (48)
pierrejoliat (02-03-2021)
Your wheels look great. I am getting the 5 star. Seems like the 245 front is a winner. Are you happy with the 285's? Do you see any downside if I went with the 275's?
2014 E550-sold 😩
Thanks. As long as you are not 4Matic, the 275 is fine. I assume it is 275/30?
The 285 is a lot of meat (which I like).
Wow The 285 is a lot of beef! I do not have the 4Matic and think that I will go with the 245/35, /275/30 combo. I appreciate your input as I wanted a sanity check before ordering the tires. I hope mine ends up looking as good as your does.
2014 E550-sold 😩
'15 S550, '10 E350 P1/P2, '02 ML320
Are you certain these wheels are 19" and not 20"? The photo above is of the 20" AMG wheels for the W221 chassis. The 19" wheels have a bit broader spokes and the center of the spoke is recessed, Sorry if you've got this nailed down, just hoping to save you some grief if possible.
2014 E550-sold 😩
I wish you luck with these and am once again unfamiliar with this OEM wheel. I hope everything fits as this power seller has guaranteed.
Post some photos.
Post some photos.
AMG DESIGN
Color:
Factory Silver
Front Size:
19x8.5
Rear Size:
19x9.5
Offset:
Front: 35
Rear: 35
Factory Spec
Bolt Pattern:
5x112mm
Condition:
Brand New
Quantity:
4
Hub Bore:
66.6mm
Part Number:
826-PL36689933
2010 W212 E350 4matic sedan P1
Plan on getting the same setup wheel size.
Here is what was listed in the ebay auction, let me know if you see anything that doesnt look right.....thanks!!!Name:
AMG DESIGN
Color:
Factory Silver
Front Size:
19x8.5
Rear Size:
19x9.5
Offset:
Front: 35
Rear: 35
Factory Spec
Bolt Pattern:
5x112mm
Condition:
Brand New
Quantity:
4
Hub Bore:
66.6mm
Part Number:
826-PL36689933
AMG DESIGN
Color:
Factory Silver
Front Size:
19x8.5
Rear Size:
19x9.5
Offset:
Front: 35
Rear: 35
Factory Spec
Bolt Pattern:
5x112mm
Condition:
Brand New
Quantity:
4
Hub Bore:
66.6mm
Part Number:
826-PL36689933
Also I am looking at the same setup for my 2010 W212 4matic 19x8.5/9.5 35mm offset. Was curious if this would work for 4matic and what tire size would I need to be close to .1%?
edit*
Other half of me wants to run 19x8.5 40mm square setup. Winter here is hit or miss and I really don’t wanna switch back and forth from winter to summer. Plus the ability to rotate and run all season tires. However the stagger look is just so much better looking.
Thanks in advance
sorry to bump a old thread. How did your setup turn out?
edit*
Thanks in advance
You'd have to run 245/35/19 and 285/30/19's for the 4Matic to work.
pierrejoliat (02-04-2021)
