Airmatic Issues?
Old 02-18-2019, 11:52 AM
Liked 20 Times in 19 Posts
CLS550 4Matic
Airmatic Issues?
So I made a thread few months ago about getting a small shake while driving. I replaced wheels, tires, pads/rotors and still exists! Now since it is much colder now, it def more noticeable. I really don't know what is going on as I took it to the dealer and they said "we cannot re-create" the sound. The slight shake is still there! I know usually there are few service bulletins on Airmatics but it was the 2010-2011 models but don't know if it pertains to the 2012+?
djrabbi is offline
Old 02-18-2019, 12:22 PM
KEY08's Avatar
Liked 364 Times in 341 Posts
2014 E550 4Matic Designo Diamond White and loaded up
driveshaft, 4Matic transfer case, axles? All can cause shake if it is not being felt in your steering wheel. If at speed and you have one finger on the steering wheel and can feel the vibration it is more than likely still associated with suspension, wheels, tires.
KEY08 is online now
Old 02-18-2019, 12:27 PM
CLS550 4Matic
Yeah the steering wheel shakes a bit at speed. It is annoying lol.
I am thinking of getting aftermarket warranty to be honest since I am so ****. Any recommendations?
djrabbi is offline
Old 02-18-2019, 01:24 PM
Liked 21 Times in 19 Posts
2013 E550 4MATIC - P1, P2, SPORT
Have you tried having a service adviser ride with you to observe it, instead of relying on them to "replicate" it themselves?
TeeEl is offline
Old 02-18-2019, 02:17 PM
CLS550 4Matic
He heard it but tech canít lol.
djrabbi is offline
Old 02-18-2019, 02:27 PM
I'd tell them to give you someone else. If it's there and it's evident I would be extremely pushy.
TeeEl is offline
Old 02-18-2019, 06:05 PM
CLS550 4Matic
I just bought extended warranty from Endurance and will make a claim later in the year. It isn't bad but had a tech friend take a look and he said just "ride it out"
djrabbi is offline
Old 02-18-2019, 06:23 PM
Liked 447 Times in 421 Posts
E250 BTC/ E320 BTC SL500
Might be long shoot, but I had a vibration on W211 wagon, that took me 2 months to track. It was changing with wheel speed, so wheels and shafts were strongest suspect.
Long story short, after 2 months of going under the car for checking, rechecking and re-rechecking, I found that control arm bushing was bad. It was hard to tell as hydro-bushings have some play when new and mine with small play was touching metal to metal. Not really big play to make it obvious during inspection, but with wheel turn that thing was resonating.
kajtek1 is offline
Old 03-04-2019, 12:19 PM
CLS550 4Matic
I went in for an oil change at a local shop and told them to look at it.
They said there is some play on the upper strut mounts and most likely what the issue is. I assume since it is airmatic, I will need to replace the entire strut/bag on that side since there aren't any parts just for the mounts on airmatic. Unless I am wrong?
djrabbi is offline
Old 03-04-2019, 01:11 PM
belarus27's Avatar
Liked 153 Times in 144 Posts
2010 e550 p2
How were they able to find the cause?? Any idea?
belarus27 is offline
Old 03-04-2019, 01:27 PM
CLS550 4Matic
He said most likely the front two stuts will need to be replaced but he said upper strut mounts def have play so don't know if I can just buy the strut mounts and do it that way?
djrabbi is offline
Old 03-04-2019, 07:21 PM
Arrie's Avatar
Liked 57 Times in 51 Posts
2010 E550
New wheels, Are they MB wheels or after market? If after market then they probably are not centered to the hub but are supposed to be centered by the lug bolts. This is not good. I went thru the exercise and my after market wheels would not stop shaking until centering rings were installed. with bolts centering vibration always came back with 65 mph+ speeds no matter how well the tires were balanced. Centering rings fixed it.
Arrie is offline
Old 03-04-2019, 07:23 PM
CLS550 4Matic
They are OEM 19s
djrabbi is offline
Old 03-05-2019, 11:15 PM
CLS550 4Matic
I think Iím going to have coilovers done as it is more cost efficient to be honest.
djrabbi is offline
Quick Reply: Airmatic Issues?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
