anyone given up on keyless go?
Old 02-25-2019, 02:00 PM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
I have gone back to the key in the ignition on my keyless go W212 to start. Got tired of once in a while intermittently not connecting to start button plus simply a place to put the key. I know you can just leave in your pocket and come & go. Perhaps this old dog can'y learn new tricks hard to say.
It's hit or miss if I use the keyless entry or hit the unlock button when I approach. I always use the key fob to lock when I get out.
Anyone else in this camp?
Old 02-25-2019, 02:30 PM
ygmn's Avatar
2015 E400 Sedan
NOPE I sue mine all the time and have never used the key in the old fashion way.
Not sure what you mean Intermittently connecting. never heard of that.
I sit in car put foot on rake and press button and engine starts no issues.
Even told me FOB battery was weak and needed to be replaced which is simple enough.
Also love just hitting door handle to lock car much easier with arm full of stuff heck hit it with your butt too works.
If I was you under warranty I would go get your keyless go fixed so it works as intended - "nothing but the best"
Old 02-25-2019, 02:35 PM
belarus27's Avatar
2010 e550 p2
Nope , love keyless go.
sometimes it does glitch , very rarely though. I can put up with that.
Old 02-25-2019, 02:37 PM
TeeEl's Avatar
2013 E550 4MATIC - P1, P2, SPORT
I haven't given up but I do have issues with it. It's always a thrill when I'm driving along and my music drops, the car chimes really loudly, and the angry red "KEY NOT DETECTED" shows on the instrument cluster.
Old 02-25-2019, 02:56 PM
cetialpha5's Avatar
Received 1,465 Likes on 1,146 Posts
Did you try the other key and have you changed the battery in your fob? I don't have any problems with mine. You could also get it scanned, sometimes the antenna goes bad and other components. But I have it on my W211 and it also works fine. The W212 is actually better as it has less problems than the W211 where the handles would fail all the time when water got inside the switches. The W212 is better designed and water doesn't get in like they used it.
Old 02-25-2019, 03:00 PM
SEC1939's Avatar
I got this key not detected or replace battery all the time. This is part of the reason I gave up on it. When not detected I'd get out of the car lock then unlock back in and typically it was fine. It just became not worth the occasional headache. Maybe I'll change my mind back at some point.
Old 02-25-2019, 03:07 PM
cetialpha5's Avatar
Did you try replacing the battery? Get a voltmeter and check the battery. New they should be 3.25-3.35 volts. I get the warning message when they drop down to 3.06. They start to act funny when the voltage is that low so whenever I get the low battery warning, I just change them right away and they're fine afterwards. You can easily pick up brand name batteries on eBay or Amazon. Usually 10 is just few dollars. I'm told the dealer uses Panasonic. They didn't last any longer than Energizer, Sony or Duracell which I've tried in the past.
Old 02-25-2019, 03:10 PM
TeeEl's Avatar
I've tried both generic and MB re-branded (Panasonic) batteries and the issue constantly occurs. Figured the issue was deeper than the battery so I'll just swap to sticking in the key at some point I'm sure.
Old 02-25-2019, 03:13 PM
DFWdude's Avatar
Received 1,718 Likes on 1,102 Posts
2016 E350 Sport
NOPE. Keyless Go works great for me. Love it.
Old 02-25-2019, 03:21 PM
cetialpha5's Avatar
What's the voltage of the battery? Store ones tend to be old and don't have as much of a charge. Plus all the fakes out there....
Also things like a phone would tend to block the signal. Mine doesn't always work if the phone is in front of the keys.
As mentioned earlier, the fobs could also go bad which is why I suggested trying the other key.
Old 02-25-2019, 03:44 PM
C280 Sport's Avatar
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
I have had cars with and without it. I do not look at it as a deal breaker.
Old 02-25-2019, 04:05 PM
P0234's Avatar
W164
I'm at the point where I probably wouldn't consider a car without it. If I'm putting something in the dash, I'd rather put an old school key in there, at least that is water proof. VW's old keyless system was the worst, you had to put the fob into the dash... so stupid.
Old 02-25-2019, 04:28 PM
Rogue Leader's Avatar
2014 Mercedes Benz E350 Sport 4matic
I've gotten that key not detected message a few times. I found hitting the unlock button on the key fixes it and off I go. I have never used the key in the ignition ever.
Old 02-25-2019, 04:40 PM
cetialpha5's Avatar
It's possible that you hit the lock button on the key fob twice. If you do that, it disables the keyless go function. I never hit the buttons on my fob so it always works.
Old 02-25-2019, 05:14 PM
thefisch's Avatar
2011 E550 P2 4M Sedan
To each his own I guess. This is now a deal-breaker, must-have feature for me. My wife's car doesn't have the smart key feature and I am too embarrassed to admit how many times I get in her car with the key still in my pocket and then sit there for a moment before I figure out what's wrong with this picture. In fact, if they offered the Jason Bourne implant so I didn't have to carry the key I would strongly consider it.
fganter (02-25-2019)
Old 02-25-2019, 06:33 PM
TeeEl's Avatar
Yeah, I have that issue with my Lincoln. "Where the hell is my button!?" But still. It shouldn't have issues as often as I have them. =\
Old 02-25-2019, 06:58 PM
fganter's Avatar
E350
I'm with you, brother.
Old 02-25-2019, 08:12 PM
DeutscheBenz726's Avatar
2019 E300 4matic
Nope
I love mine BUT! When I first bought the car it would start with the keyless go but wouldn’t shut off. Then I started getting the key not recognized bit and THEN the car started going into park whenever you slowed down to 2 or 3 miles an hour. Turns out it needed the electronic ignition switch replaced. $950
Still waiting to hear from MBUSA to see if I can get some goodwill money back
Old 02-25-2019, 10:21 PM
NickTH's Avatar
2015 E400
This feature works well most of the time.
Once, we had to bring back to dealer to get the module in the trunk fixed under warranty to make it work again.
I still think "KeyLess Go" is a misnomer & a scam $700 option, since unlike my Vette, you really can't just walk away & go, and vehicle locks itself. You must physically touch the handle or push button on key to lock....
Old 02-26-2019, 08:32 AM
SEC1939's Avatar
On the rare occasion the wife uses the car and she is at the mall when this happens it will be panic time.
Old 02-26-2019, 03:31 PM
jonUF02's Avatar
2015 GL550 4matic
Yeah, I gave up when I bought the car that didn't have it! Actually keyless systems make your care extremely easy to steal. Thieves get a box on the black market that will capture the signal from your fob while it's inside your house, and use that code to activate and drive the car away from your driveway. Are we really so lazy now we can't just carry the keys in our hands? I keep them in my pocket all day every day, any time I'm not at home.
Old 02-26-2019, 04:03 PM
cetialpha5's Avatar
While that's possible it's not very common. It's why you have insurance. If you're worried about that, you mind as well worry about people with tow trucks stealing your car. Or people with a bump key picking your lock and robbing your house. I have a parking lot anyway so they'd have to figure out where I lived first and the thieves are banking on your key being near the door or able to communicate outside the house. If it's stored deep in the house, it wouldn't have the range to capture the signal and repeat it to the car. Plus you can either shut off the key by hitting the lock button twice or put it inside a faraday cage if you're really worried about it.
Old 02-26-2019, 04:10 PM
jonUF02's Avatar
2015 GL550 4matic
I live in a popular older neighborhood with "bungalow" type smaller houses from the 50s and 60s, it's pretty common occurrence according to my neighborhood social app. Lots of newer cars stolen without keys.
Old 02-26-2019, 04:27 PM
BillyT293's Avatar
2016 E350 4Matic
Same. Get the key not detected message occasionally but thats the extent of the "problems". Just take it out and hit unlock and then I am good to go.
Annoying? Sure but its a first-world complaint in my book.
Old 02-26-2019, 08:33 PM
TeeEl's Avatar
...according to my neighborhood social app.
Ugh. Those things are the worst. "Have you seen my dog?" "Who is this person?" "I lost my dog." "What's that noise?" "Anyone find a dog?" "What's the weird light in the sky in the middle of the day?" "Reward for dog."
But maybe I'm the only one who lives around really ****ty pet owners.
Quick Reply: anyone given up on keyless go?
